1990 country squire resto/lowrider in UK
    Originally posted by rellik god View Post
    will the bumper shock be in the way of the new mount location.looking good andy
    Yes! Not using bumper shocks no more! The end of the rail will be up behind the bottom of the tailgate! Wont fit.
    I will redesign the bumper mounts - eventually.
    Andy.
    www.lowcamaro.com
      When you're done, will there actually be any metal on this car you haven't repaired, replaced or modified? Impressive work dude, most people just don't have the capabilities of doing this involved of a resto-mod.
        +1
        Very much looking forward to seeing this done and scaring the neighbors.
          Hi gadget73.
          There will not be much sheet metal left that I haven't changed at the end! And so it should be!!!
          Rear floor cut right across the back so it can go up when the body is dropped around it.
          I now need to remove the top of each rear wheel arch to enable the wheel/tyre combo to go further up
          Heres the level marks to determine when the floor is at the new desired level. Lowest mark is at 6cm, then 8cm, then 10 com.
          Andy.
          www.lowcamaro.com
            I bet the untouched metal will amount to the hood... and maybe the roof.
              I have to say this is a very ambitious, and well done, project.
              Axle codes
              Open/Lock/Ratio #
              G / H / 2.26
              B / C / 2.47
              8 / M / 2.73
              7 / - / 3.07
              Y / Z / 3.08
              4 / D / 3.42
              F / R / 3.45
              5 / E / 3.27
              6 / W / 3.73
              2 / K / 3.55
              A / - / 3.63
              J / - / 3.85
                Hi Slymer.
                No, the hood will have 2 cuts down it and then the centre raised up - cowl induction style.
                The roof will have the rack removed and the holes welded up.
                So that leaves.....errr...............nothing!
                Andy.
                www.lowcamaro.com
                  Here is the intended firewall cut - red line you can just about see.
                  I will cut out the steering column hole (red line) (can you cut out a hole?!!) and weld it back in later.
                  Andy.
                  www.lowcamaro.com
                    WOOOOOOOOOOOOOOWWWWWWWWWWWWWW
                    '88' MGM wagon (mine and my sons toy)
                    "60" chrysler New Yorker (my project)
                    "78" Chevy 1 Ton P/U (yard horse)
                    "01" Ford Explorer (wifes DD)
                    "93" Chevy Suburban (my DD)
                      Final bit of cutting done before we get to the firewall and the big cut!!
                      Andy.
                      www.lowcamaro.com
                        When this is done we should have a separate thread with just Andy's posts and pics with brief explanations, a total build diary. Without all our comments and kudos interrupting his brilliance.
                          the "How to slam a panther wagon" thread. We do have some epic how-to's on here. that would be the MOST epic.
                            Making me want to cut on stuff again .... gah.
                              Here's a chunk of the firewall missing to enable the floor to move up 10cm.
                              And here's the floor finally moved up 10 cm all round..
                              Here's a view of the rear tyre/wheel looking good tucked up underneath!
                              View from underneath later
                              Andy.
                              www.lowcamaro.com
                                That looks good!!!
                                Click on picture to see the video!
                                My other cars: 1986 Mustang GT 1967 Ford Fairlane 500, 2dr hrtp under construction
