Trial fitted the side panel and a right angled strip
Strip spot welded in on top of rust proofing fluid that has now flowed all over because of the welding heat
Vertical panel etch primed on the planned tough to reach areas and spot welded in
Next I will produce a second vertical wall running alongside this one and close it all off to mimick the factory setup.
Andy.
Andy.
