    looking good as always mang!
      Looks good. How did you make the seat switch holes, drill a hole and then file it out to square ?
        Thanks mangs. And Thain, almost. I drilled a 1/2" hole. That gave me the correct clearance for the switches to poke through. Then I squared off the circle with a sharpie then used a thin dremel attachment to get the circle square looking (the hole in the left of the photo). I cleaned up the squarish hole with a couple different files.
        In order to even get to that point I had to mark those holes to drill'em. To do that I put blue painters tape on the back side of the seat trim and placed some butyl tape on the center joy stick then fitted the panel. The butyl leaves a mark on the tape. Drill on that mark. Drilling out the center joystick hole allowed me to mark out where the up down switches will be. Same method butyl tape. Drill out those holes then repeat for the two screws.
        Oh and Thain Thanks a million for noticing them. Believe it or not I almost left the place without pulling them because I thought I may not be able to use it (I had power seats). My dad was in the truck section cutting out quarter/rocker pieces for his explorer. I decided I should grab them because when will you ever see them again?
          That came out really nice. Car looks great as always.
          Past Panthers
            Not a problem. I'd much prefer that someone pull and use them than see a nearly unobtainable part turned into a cat food can.
              I can't believe that CV hasn't won any trophies. I would be willing to bet that most of the Mustangs and Camaros in the shows are nowhere near as nicely detailed as that CV.
                he's gotta take it to a show first.
                  Yeah, not interested in shows, myself. Just enjoy driving them!
                    I did win a trophy.
                      As well it should.....
                        Installed the passengers side seat trims today after making all of the necessary holes.
                        Next up is mocking up the police box panther oil cooler.
                          Thanks by the way. Now I have to find a Mark VI with side seat trim to obtain, and then fit it to my car.
                            Yikes, that is going to be a tall order.
                              Rock Auto order was put in today. Motor mounts are on the way. Will get to them someday, most likely when the bb swap goes underway.
                              Purchased a hood liner and clips a few weeks back as well. Takes about a month to get here though......Wonder if they are made to order?
                                Big Block swap?........TELL ME MORE!!!!!!!!....lol
