ultimate huh? looks like i need to stock up on meguires stuff. i know i need to clay bar all my cars lol. my lincoln can get bad, if i dont keep on it. plus, i noticed that it is harder to wax too.
Fog Lamp switch installed
Figured I let the paint dry enough to assemble and install the fog lamp switch into the car so I went for it. Results....
As you can see I did not bother purchasing the SEM sand beige paint. I priced it out and it would have cost me nearly 50 bucks. I just couldn't justify it because the piece was so little to paint in the first place. I like the slight contrast this paint produces.~David~
As always - ME LIKEY!! Looks "factory"!!
still looking good mang! ever thought of using a 88-89 lincoln horn pad? i got one in my wagon and i think looks good.
I don't know what they look like Julian. Maybe I would like it?~David~
meh. any pics with your wagon?~David~
ill try to get one for ya.
Here are the aluminum wire separators....with some slight modification...CHOPAGE!
Had the fabricators at work chop a bit off so all can clear the fuel line as well as the compressor bracket. Had to drill and tap as well as counter sink a new hole because the preexisting screw location was cut off.
Here you can see one side scuffed and ready for engine primer and paint etc...
The pieces will be painted in the aluminum color I have in my engine bay already. The four collective allen headed screws will be painted in low gloss black.
Tuesday morning I am shooting for painting them at the shop.~David~
Originally posted by 87gtVIC View PostHere are the aluminum wire separators....with some slight modification...CHOPAGE!
Dave rolls big. Looks good! I think it's a good idea you decided to paint them, that way you wont have to worry about polishing them every so often. I'm looking forward to seeing what they look like installed!-Phil
