    what maf do you need to match on that?
      Not so sure how that all works but a 24# maf I would have to guess.
      I'll probably have to purchase a marauder air box as well because mine has the card style maf. All of the other mafs I see are different.
      Now I see 24# mafs come in all different size tubes....mm wise. I don;t know what that means or if it makes a difference.
        oh boy/....Just purchased a MAF from an MKVIII...one step closer.
          use a stock MAF and tune the ECM to match the injectors. The "calibrated" MAF just feeds a modified signal to fool the computer into thinking its getting less airflow in order to shorten the pulse on the injectors so they more or less work right. It doesn't really fix it 100% and it won't optimize fuel or spark curves to an engine that actually needs more injector. If you're running a MAF other than what went with your particular ECM, you program the MAF curve into the ECM and you're golden.
            David, you will be doing an engine swap in no time! None of this next year crap
              Highly unlikely. I want all of the suspension stuff done before the go fast stuff.
              Thain I understand what you are saying. I see there is a lot of confusion surrounding the net with how mafs work. I see aftermarket mafs are calibrated to trick the computer, ford mafs are just mafs and the information is changed in the computer to work with the maf. At least that is a very rudimentary way af me describing maf.
                That's how I am doing it. After the engine goes in, then it's paint time. I learned with my old Malibu that putting in a 496BBC just kills the [stock] suspension. DOing the suspension and engine work after painting will promote scratches. Lesson learned......the hard way.
                  rebuilt ford/ denso 24# injectors came in today! Made me pull out the fuel rail from the shed. Will clean it up tomorrow and maybe even paint it the as well. If not paint will happen Friday.
                  Also picked up a set of NIB Ford Racing 3.73 rear gears for a song.
                    Installed the injectors onto the fuel rail then onto the lower intake.......wrapped everything back up and put it back on the shelf.
                      Looks nice and clean. It's probably already answered somewhere in this thread, but what cam are you using with 24 pounders? And are you using an A9P computer?
                        Thanks...that is just the tip of the iceberg......you wait until everything is bolted onto that engine.....a year or two from now. lol
                        A9P and here is the part number for the cam: TFS-51403001
                        It is the cam from the TFS Top End kit from Summit.
                          perty
                            Sweet!!
                            Past Panthers
                              Welp...TFS 170 heads are on the way......got a deal on a new set through the corral.
                                nice
