Price Motorsport Engineering
302 boss
Next question, Can I put a 4V intake on a set of 2V heads?1989 Grand Marquis LS
But you're doing it on a 302, so no 351-based intake will work.FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
Junkyard HO, MSD wires, stock Mustang headers, off-road H, Hemi Super Turbos. 3.55 trac loc, HO governor and servo in stock rebuilt AOD. 3-row rad, air pump delete, cop rear bar, wagon rear springs, 93 CV rear discs, 98-02 Grand Marquis wheels, Class 3 hitch, aluminum space-saver spare.
Coming soon: 98-02 front brakes, cop springs, Monroe cop shocks, 96 Cobra wheels w/255/50/17. Better yet, need a nice wagon to put all that stuff in.
But all the 302 boss motors had 4V heads. I use 2V heads and a factory boss intake I wanna make sure its gonna bolt together.1989 Grand Marquis LS
Oh, OK. You've got a factory Boss 302 intake laying around? In that case, I havevery little useful input.
The company mentioned a few posts back, http://www.pricemotorsport.com/ does not seem to list a solution to your problem on their web page, but I bet they know the answer.
IMHO, the value of this project is strictly "doing something different." If you have all these Boss parts around, you could sell them and buy modern parts that will outperform the Boss stuff in every category, and would be a direct bolt-on too.FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
There is no need to use an expensive factory boss intake. If you buy the adapters you can use any aftermarket 302 intake with the Cleveland heads. And it will perform better. The Boss intake has such large ports that the port velocity will be lower then a standard 302 aftermarket intake. You combine that with the much smaller port of the 2V Cleveland head and the airflow will be even worse due to the large step the airflow will have to take.
Pick up a cheap aftermarket intake for a standard 302, Buy the adapters, and pick up a pair of 2V cleveland heads. The adapters will give you a smooth transition from the intake to the heads and you'll get much better performance then you would with the Boss intake.
You're referring to a 4V as just any 4 barrel 302 intake, not a 351 4V intake. I get it. I should go to bed now and quit being stupid...FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
Originally posted by Southern_PrideBut all the 302 boss motors had 4V heads. I use 2V heads and a factory boss intake I wanna make sure its gonna bolt together.
Originally posted by Fordman75You can bolt a Edelbrock SuperVictor intake onto a standard 302 too but it doesn't mean it's going to run good on the street!
Ford's own performance manual from the early 70's recomments using the Cleveland 4V intake on a Cleveland 2V engine for a 30+ HP boost.
You are making a wrong assumption.
Yes it may work fine on a 351, not optimum, but it may work. But on a 302 the Boss' intake plenum/runner volume is just too large. It may idle fine but the throttle response will just not be as good as you'd have with an standard aftermarket 302 intake. Top end would be great(if you blended the ports on the heads for a smooth transition ) but the low end it going to be a little soggy. Just like with a Boss 302 only not quite as bad.
