Whatever it is, looks like it's got a Quadrajet on it...I'm guessing that's not the original, eh?
1985 Lincoln Town Car Signature Series But God demonstrates his own love for us in this: While we were still sinners, Christ died for us. Romans 5:8
Yeah, I heard about this one... if this is the one that Scott was all in knots about.
The head casting is C4AE 6090G, correct?
From what I've found, those are 352-390 heads; Pirate told me he thought that casting # was for a 352...
Scott gave us something off the block, but it wasn't meaningful in determining much (30 DIF). I would think Mercracer could tell you what it all is if you give him the right casting #'s, etc.
At any rate, the only way that I could ID an FE vs. a 385 series engine is via the valve cover shape, and the intake/ heads. I couldn't tell the difference from just the block, etc. But, my old man has an abundance of 390 (as well as 460) parts laying around, so I suppose I could study them for differences for my personal benefit.
But, thats definitely an FE engine right there...
**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser **2006 MGM,"Ultimate": 4.6/ 2.73/ Dark Tint, Magnaflows, 19s, 115K Daily Driver **2012 Harley Davidson Wide Glide (FXDWG):103/ Cobra Speedsters/ Cosmetics, 9K Poseur HD Rider **1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Truck Duties
An FE is going to be an expensive build (not that a HiPo 460 stroker build won't). But, unless you have some really good (by good I mean good for performance) FE parts (heads, etc), you probably won't be able to make the power you could with a 385 series engine. As far as I know, good FE parts are pretty durn expensive.
Its an FE motor bored and stroked to the max it could become a 460 but I doubt it has been.
A 352 or 390 will never be bored to a 427....... You would end up with paper thin walls long before that....... It takes a 427 block and a 428 crank to get that many cubes........
Some of the early blocks can be bored to a 428 size though..... 4.05 to 4.13 takes a thick block... to go another .100+ would be silly to even try.....
The C4AE-G heads were used on both the 352 AND the 390. FE block casting numbers are on the passenger side of the block toward the front. The casting date is on the drivers side under the oil pump area viewed from the bottom.
The FE valve cover bolts half to the intake and half to the head because the intake port is very short. The block is a Y block design so the main caps are tucked up inside the block. The valves are inline where the 460 valves are canted.
The thermostat bolts to the FE intake from the front. The 460 (385 series) is the only Ford engine that the thermostat bolts onto the intake from the top. The FE also has a hole in the intake for the distributor to go through where the 460 and small blocks intakes go around the distributor.
A FE is cheaper than a mod motor by far. It is definitely cheaper to build a 460 but if you want to stay in the 400-500HP range, an FE really isn't all that bad. The trick is to keep the RPMs low.
