Does this look like a 460?
    Originally posted by Mercracer View Post
    A FE is cheaper than a mod motor by far. It is definitely cheaper to build a 460 but if you want to stay in the 400-500HP range, an FE really isn't all that bad. The trick is to keep the RPMs low.
    OK. But I'd say it depends on the severity of the build still.
      Originally posted by Grand_Marquis_GT View Post
      Sure doesn't look like no 460 to me
      It looks like someone boogered up the valve cover rail on the intake.... lots of RTV....
        Doesn't the FE engine also have a unique bell house bolt pattern?
        Tom, now you're gonna have to buy yourself a late 60s-mid70s F150 to stick this in.
          The 'round bell' bellhousing, yep. There are, however, some early 460 blocks (Lincoln 460, C9 and D0) that have the FE bellhousing pattern.
            Weird, That sure doesn't look like the 460's we have a round here....then again most of the ones we have are from late model trucks...lol
              http://portland.craigslist.org/mlt/pts/616065159.html
              http://portland.craigslist.org/clk/pts/613232707.html < Full assembly including accessories $315......has some lifter noise.
              Tom the problem is is that your on the wrong coast!
              Intire RUNNING Parts truck....$450
              http://portland.craigslist.org/clk/pts/613265648.html
                Um Jay...
                It's NOT a 460!
                  Mercracer, your info on engines amazes me.
                    I love my 390 in my 65 marauder who ever says that they can't rev doesn't have much experience with one with a good cam. Id be afraid to take my 302 as high as I take that motor. If you don't want that motor I do! Mine makes excellent torq from launch and doesn't stop pulling until close to 7000. You ever see a 6000 pound car go sideways from a launch on dry pavement?
                    1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
                      I'd love a marauder like that too!
                        maybe because its an FE motor, either a 390 or a 352? Could just possibly be why it does not look like a 460.
                          Even my gf said it doesn't look like a 460.....lol and I don't think she has even seen one other then my mags and catalogs...lol
                          Then again she's into FSB's so perhaps she saw one in there.....I dunno.
                            Absolutely NO 429/460 has the FE bolt pattern. You have the Lincoln 462 (even those aren't C9 or D0 though) confused with the 460.... By 1969, the 385 series was the only Lincoln option. C9 and D0 460 blocks are all the standard 385/335(most 351M & all 400) series bolt pattern.....
                              Originally posted by Nathan in MN View Post
                              Whatever it is, looks like it's got a Quadrajet on it...I'm guessing that's not the original, eh?
                              The only Ford motor which ever got a Q-Jet is the 1970-1971 429CJ/PI. Ford released its own spreadbore in 1971.
                                Of course the engine will physically rev..... The issue is reliability.. The oiling system is exceptionally poor on the FE. You may be able to get away with a stock oiling system on a relatively mild 390 build, but step up the stroke and the shortcomings come through... The 427 and the 390 have the same stroke.... The 427 has a huge bore in comparison... The 427 needed a different block with an improved oiling system to live at high RPMS reliably...
