Have you found your Buildsheet?
    If so, list where. Include year and model.
    1982 LTD CV 4D - No Buildsheet located
    1987 CV LX 4D - One under front seat, one under trunk mat
    1987 CV P72 - Under front seat (car in junkyard)
    1988 CV Wagon - Behind left taillight
    I found a lump of mush underneath the trunk mat in the CV that I'm pretty sure used to be a build sheet.
    Never looked for it in the Linc, but it's probably around somewhere as well.
      1981 Ford LTD - Crammed Under The Dash Pad
        1985 LTC - Inside front passenger side seat back
          1987 GM - Under trunk lining
          Cardomain page
          "It's not rocket surgery!!"
            in the 2 door i found a build sheet under the passenger door panel, passenger seat, under the hood insulation, on top of the headliner, lol so i have 4 so far,
            in the 4 door, i havent found one
            both cars '84 as you all alredy know
              86 Crown Victoria - Bottom of the driver seat stuffed above the springs.
                1984 GM - on the bottom of the front passenger seat
                  1990 CVPI: Under the front drivers seat, stuffed above the springs.
                    1986 Grand Marquis LS-Coupe - Stuffed under seat springs and inside of the seat back (pop off panel).
                    1986 Grand Marquis LS 2 Door
                      Thanks for the responses! Keep 'em coming!
                      Dave! Holy Crap, four buildsheets! Wow.
                      Saiyaneye, I figured mine in teh '82 was probably stuffed in the dash somewhere. I'll have to check into the dashpad!
                        Tiggie do you have anything to decode my buildsheet? I can scan if you want
                        --Edit--
                        Crap I will have to hunt for it...
                          1989 gm 4 door
                          behind passenger seat back
                          under drivers seat stuffed under the seat springs
                          under the trunk mat
                            I also found an Ford Fuse (one of the bigger ones) under my carpet :p
                              I'm still nervous about what to do with mine since I only have one good one, the other is wrinkled & torn. I have it in stuck in the middle of my new Ford manual which is my baby. I might make some good copies, and put it back inside a ziploc bag.
