That would do it. Big vacuum leak.
Monty's 1989 CV LX
This is such a great-looking car. You're basically doing what I want to do with mine: restoring it back to a like-new factory condition. Mine will need a paint job some day and I'm mulling the idea of a color change; whatever I go with will have to work with the blue interior since I have no plans to change that.
Keep up the good work! Looking sharp!—John
1985 Ford F-150 XLT Lariat
Majority of the car has been wet sanded with 400 grit. I'll have to go over it again and check edges and corners for any issues. Tops of the doors around the windows aren't done, yet. Not sure what I'm going to do with the door jambs. Suppose I could put the hood back on, so that is out of my way. Definitely need to spray Primer Sealer. Sanded through the primer in a few spots. Otherwise, it's straight and getting a little closer to paint.
If you are going with a metallic paint I would go over the car with 600 before spraying. The metallics could settle in the scratches left by the 400.~David~
Trick I used for the hood: Bolt the hood to the hinges, but keep the bolts just a bit loose. Then close the hood all the way. The latch lined it up almost spot on. Then, I popped the hood, raised it just enough to reach the hinge bolts, and tightened them. I never removed the fenders, though. I can see that being a real headache to align them.
That's how I did it but the hood doesn't want move much, and when it does, it's then grossly over to one side or the angles are off. Now it's good, but needs to come forward more but at this point, you can shut the thing and the lines are even with the fenders so going to wait awhile before I mess with it again haha.1985 LTD Crown Victoria - SOLD
So cool!
Must be exciting.~David~
