My 1979 F100 (Project effin'hundred)
    UPDATE!
    Found a good running DOHC 4.6, but it's in Michigan. Price is right, and shipping shouldn't be much. Wish me luck!
      Originally posted by Tom View Post
      UPDATE!
      Ah, guess not. The search continues
        i'm tellin you, find a complete wrecked mark 8. would be much cheaper to do that then just get the motor, then buy the suspension and wiring separate. Complete car gives you all that in one shot, then you scrap the remains.
          People want a damned arm and a leg for wrecked mark 8's, parts cars, or even those with some defects. I can't win.
            I don't know what year 4.6 you're looking for, but I just seen this http://stlouis.craigslist.org/cto/2514737353.html for $900
            http://stlouis.craigslist.org/cto/2525282098.html & this for $1550. Do the MKVIII's have an aluminum IRS? Otherwise I would get a dirt cheap MN12 with a 4.6.
            __________
            //___l__,\___\,__
            L/-\_|___|/-\[OIIIIO]
            _(o) )___(o) )--(o) )
            1975 Mercury Grand Marquis
            1990 Lincoln Mark VII LSC
            1996 Jeep Cherokee Sport
            2001 Mercury Grand Marquis
              I believe he is wanting the dohc 4.6 from a mark viii for the teksid block. Correct me if I'm wrong Tom, I don't know my modulars that well.
              '90 LX 5.0 mustang
              Big plans
                I want the Teksid. They are the shizzle. And aluminum. Sweet!!
                I'll let you know when a Mk8 ends up at Tonys.
                There's another upull up here that usually has mk8s in it. They charge about 125 for the motors, If you pull it. If you want to rebuild, this is the way to go.
                (If you wanted one from up here, that would give me a reason to put a hitch on the Tank like I've wanted to. Plus road trip)
                08 Lincoln Navigator L - 233k
                03 Mercury Marauder- 63k
                  Got a good condition pair of doors and tailgate today. Had to drive a ways for them, but 50 bucks is a steal
                    More inspiration pics. I plan on doing this with the grille, same general ride height, and same style of wheel (have in stock).
                    No trim, though.
ID:	1267720Click image for larger version
                      That is a very pretty truck. Easy to be inspired by that.
                        I ain't quite sure when the truck is gonna go under the knife. Might be awhile. In the meantime, I can collect parts
                          Are you going to run 17's or 18's on the wheels?
                          '90 LX 5.0 mustang
                          Big plans
                            I have a set of 17" 05+ Bullitts that came off my GMQ. I'm going to use them.
                              That is going to be a wicked truck! That 03+ Crown Vic front suspension is a sweet set up to swap into the Ford trucks.
                              Hey are there any parts you need off my 78 F150? I'm going to be tearing the body off it within the next week or two here. If you need anything just let me know.
                                Ted,
                                If you come across the following items:
                                Ford Sport Steering Wheel
                                Tilt column from a 4 speed truck
                                And that's about it. Everything else, I can get readily. Thanks mang!
                                Tom
