    that is awesome!
      And here is the new list of shit to install on this car.
      1. Chevy. GMC Truck Sport Lower Valence (Has fog lamp holes)
      2. Sexy mini Marchal fog lamps from Rangers/Escort GT's
      3. Addco 509 1 1/4 Front sway bar with enlinks etc.
      4. Stock Box Panther Police Oil cooler
      5. Big brake upgrade/ Complete with Energy Suspension Poly Bushings I had installed over at Scotts
      6. Engine mounts
      7. Ford Racing 3.73's Complete with ford racing install kit
      8. Trac Lock Clutch Rebuild kit
      9. Ford racing rear dif cover
      10. Tubular GT 40 upper intake with matching lower
        [* Fuel Injector Rebuild Kit
      11. Lightning EGR Spacer with matching lightning 65mm throttle body
      12. Motorcraft thermostat
      13. Motorcraft PCV valve with new pcv screen and grommet
      14. Cast Aluminum Mustang Valve cover (a different set to be painted with VHT wrinkle paint)
      15. Crane 1.7 Roller Rockers
      16. Ford racing 1/2" intake spacer
      17. Repainted 1979 Specific License Plate housing
      18. Sexy color matched to car rear license plate cover (like the one on my Escort)
      19. Town Car Underseat courtesy lights
      20. HPP wheels!
      21. HAVE TO FIND DRIVERS SIDE FENDER..Mines rusting like a banshee!
      I think that is this bulk of everything.........
        I have no clue what my car can tow.
        HD Tow package cars are rated for 5000lbs, 5.8's for 6000lbs.
        That hitch looks like the older version of this one.
        http://www.summitracing.com/parts/ch...crown-victoria
          The hitch is a handy thing. I've used mine a few times, but not nearly what it used to be used for. My car was bought to tow a 2 horse trailer. I've pulled two Towncars and my S10 on a tow dolly at different times with it. I've also used it to haul a fair size flatbed trailer when we were moving. I don't back stuff down the ramp because I don't want the salt water on the car but I have little doubt it would do what I ask as long as I got traction.
            Did more work today.
            Installed the Lincoln Town Car Under seat courtesy lights! Since the seats were out I also tapped out a seat mount hole for a bigger bolt as it was stripped.
            Can't see much:
            And I cleaned up the interior and took some new photos.
              That looks very similar.
                Nice and clean as always! But, how do you already have a rusty fender?
                  It was rusty before, both of them were. I cut out all the rust I saw at the time but other areas had rust that now showed its ugly rust head. I should have known that where there is some rust there will be more. It sucks but oh well. I have a minty p.side one already. I just have to find a d.side one that is just as nice. It definitely was a learning experience.
                    Looking good. Sucks about the fenders. What's the plan? Install new ones and paint/blend to match?
                    Past Panthers
                      I am not sure what the plan is. I really want to wait on putting the fenders on until AFTER i have new engine installed. When that is, who know? Having the parts in my possession though is half the battle. I planned to take the entire front clip off and fix whatever needs fixing and install new engine then.
                        Finished making my gt 40 tubular intake cover. This started as a flat sheet of aluminum and after some jigsawing, filing, bending, welding, grinding and sanding you have this:
                        It is getting painted tomorrow.
                          Makes sense. Do the mechanicals then focus on fixing up the body. The rust you are talking about never shows up in the pictures, so you probably have plenty of time before it becomes a major issue.
                          Past Panthers
                            I learned with my old Malibu that all suspension and engine work should be done before the body and paint are done. Even if you're just doing a $400 Maaco special.
                              you have one hell of a car.. that thing is amazing.. you sir are missing only one thing a sub
                              Charlette - Brown 1977 Ford LTD - 351 Windsor 155K, Full Custom Pioneer system, green HID, interior & underbody
                              Alesha - Black 1982 Mercury Marquis - 255ci 178K, full custom Kenwood and Infinity system, lowered, dual exhaust, LED all the things
                              Tangerine Dream - Orange 1988 F-150 Custom - 300 i6 82k, Ghetto sound system, 5spd, 2WD, #farmtruck
                                Agreed. I'd like to have a small sub with the amp built into it. I just do not know what type to purchase. I think bazooka sells/sold? subs with built in amps? A little bump is really what the audio system needs.
