The 93 GM "Tank of Justice II" (TOJ2)
    Sorry about the delay. But the video will be posted after lunch today.
    Priming the chin spoiler on Tuesday or Wednesday.
    Then the GFG goes on.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      I am still waiting for the fender skirts. Or, if you'd like to make them sound not-so old person...wind spats.
        Ok Logan, here's your smokey start up.
        I can get a etter one later.
        Here:
          yup... looks like mine before the engine ate itself.
            Those might be going on sooner than I thought Scott.
            But I have a host of other things to do first (State inspection, alignment, tires, exhaust, chin spoiler, motor, trans, etc,.)
                Being the ecoMod project what other weight saving plans do you have for it? You could ditch the tailpipes and run 45 degree turndowns pointed sideways, remove the rear seats and use racing seats, and replace the rear window glass with polycarbonate. Also I see steelies in the last pics, I assume those are winter wheels and you have lighter alloys for the warmer weather right?
                  Yeah.
                  Those are the 17" steelies for the Town Car. I need those for the algnment this week. I have a set of 15" steelies that are offically ready to have tires put on them.
                  I need 2 snow tires from my old 15" alloys removed and mounted on the 15" steelies, and then I bought 2 new snow tires to be mounted on the other 2 15" steelies.
                  Then the 17's go on the Town Car.
                  I may end up doing that with the exhaust, but we'll see.
                  I'll probably end up removing the rear seats, since it will be my DD, and I'll be the only one in it.
                  Also, I did buy an aluminum Teksid block that will cut 85 lbs off the car. I'll get to that as soon as I finish these "other wheels" that I have around here.
                  So my motivation is clear.
                  Time to get moving.
                        '79 Continental Town Car
                        '90 Crown Victoria LTD
                        '94 Crown Victoria
                          I like it, photoshop the whole rim lip green, see how you like it.
                            If I knew how to Photoshop, then I would do it.
                              You're pretty good with MS Paint, puts my drawings to shame.
                              Do they make colored trim rings? I thought about those when I had my Vic, it was red so I figured red trim rings would look good on the steelies.
                                Not really.
                                All I did was find the blueprint of a Grand Marquis and fill it in.
