The 93 GM "Tank of Justice II" (TOJ2)
    I'd probably free hand it, and come up with this:
    Anyways what's left on engine work? I assume you're building something like a 4V 4.6 with that Teksid block to replace this engine when it dies.
      It's basically dead now...
          That's been the case for 3 or 4 years now. But the Tank don't die.
            it's the UNDEAD!
            well... now that Zach's 92 of the undead is no more
              I'm actually building a 2v PI replacement for the Tank because it's my fuel economy car.
              I've been sloooooooooowly working on it.
              Moving and stuff has kinda put a damper on progress.
              Until Thursday happened:
              08 Lincoln Navigator L - 233k
              03 Mercury Marauder- 63k
                I'm liking the steelies with the green stripe!
                  Monthly Update!!
                  Wow, it's been a while.
                  The Tank broke 222k on Sunday, which was nice.
                  In other news, I've put the 4 snow tires and rims on it, and I aligned it at my buddies shop.
                  The exhaust is broken in around seven or so different places. So that needs to be shored up as well.
                  And, I filled up the gas tank on Sunday. It leaked all the way back to the apartment. I had a huge fuel leak where the fuel pump lock ring is. I lost around 10 gallons of fuel.
                  But, I saved about 7 or so gallons of gas.
                  I fixed it last night. I resealed it, and now I have to wait until tomorrow to refill it and see if I actually fixed it.
                  I have a few things to take care of this month, on top of working on the house.
                    Including a certain set of rims?
                      Getting there.
                        Ok, going to put a new h-pipe and mufflers on tomorrow night.
                        I'm powder coating the mufflers in hi-temp flat black. That should cut down on the corrosion.
                        I also bought VHT hi-temp paint for the exhaust as well. Last time, I used the DupliColor hi-temp stuff.
                        And it all rotten anyway.
                        So bought the better stuff, with silicone in it. I figure that I'll inspect and/or repaint the exhaust about every 6 months to make sure it's holding up.
                        At this point, it's just annoying.
                        I'm averaging around 500 miles a week. This exhaust issue needs to be fixed ASAFP. Then I can hypermile it again and pound down 500+ mile tanks.
                        Ok, off to work and stuff.
                          Using Thrush Turbos again? I've read the Super Turbos flow a bit better because of the flow directors in them and they'll get a bit better mileage, but probably not enough to notice.
                            Maybe nexy time, when I replaced them again in 5 years.
                            Or I'll just go with stainless steel ones.
                              I like the steelies with the green stripe as well. Maybe get center caps and somehow get some metallic green paint on them?
                                I could powder coat them.
                                But I'd have to find a set first.
                                Maybe.
