adjusting lock striker?
    so basically- lube your hinges at every oil change
      Have been. When I got the car, I opened the rear drivers door and it barely wanted to move...I guess the old guy never drove anybody around in the back seat so he never used the door. WD40 saves the day!
        WD-40 is great for freeing stuck, dirty parts, is that what you use to lubricate it at every oil change? If so i'd highly recommend using white lithium grease instead. It will stay where its sprayed and continue lubricating long after the WD-40 is gone
        -Phil
          I usually hit it with WD40 whenever I think of it, which is more often than oil changes. white lithium grease, you say? Is there a particular brand or it just a generic product or..? I'll grab some tomorrow when I'm in town.
            I dont have a particular brand to recommend, currently i'm using liquid wrench brand white lithium grease.
            -Phil
              Basically WD-40 is more of a solvent, so it cleans it up nice but wont lubricate long. I just use some of the grease I use in the front end for the tie rods etc, which also get greased every oil change.
              1985 GMC 1500
                adjusted the striker...no big deal. i'm assuming there's no set position that is best for every car, you just have to adjust and check, adjust and check, adjust and check?
                I think someone misadjusted this one at one point, it was on way too much of an angle to seal the entire door properly.
                The striker can only be adjusted by spinning it around, right?
                  ...spinning it around? It's a striker head but it's got threads just like any bolt that thread into a welded nut inside the pillar. You unthread it to loosen it and then it's able to move around every which way.
                  You mean they'll go bad eventually? What are signs it's gone bad? It doesn't seem to close quite as tight closer to the hinge than at the rear of the door.
                  Are you saying the forward edge of the door doesn't line up with the fender as well as the trailing edge lines up with the rear door? If so, that's a hinge alignment issue, not a hinge pin or striker issue.
                    As in spinning it in a circle. Is that the only direction it can move?
                    (pic stolen from 87gtvics thread about striker replacement
                    The forward edge of the door had more wiggle room between the stripping/door than at the rear edge of the door
                      Disregard previous post. I didn't want to end up unscrewing it all the way in fear that I'd never get it back in (in case you haven't guessed, I'm not exactly mechanically inclined) but I loosened it even further and there's room to move it around however I wanted. 2-3mm closer at a very slightly different angle = no leaks yet.
                      Haven't had it through the pressure washer (and I don't own a hose) but we've thrown a whole lot of buckets of water at it and no leaks after this last attempt. I would jinx myself by saying it's fixed but I will say "so far so good"
                      thanks everybody
                        Yes, I've guessed you're not very well versed in automotive mechanics. However, in the brief time you've been posting here I've noticed you improving quite a bit, and you're no dummy so I have no problem helping you learn. In fact, I am more than happy to provide any help I can.
                          Thanks man. I basically only know what information I've gleaned from these pages.
                            Good for quieting noisy hood hinges too!
                              hood hinges are supposed to squeak and groan like crazy (especially the ones with the "if it breaks someone dies from the shrapnel" springs)
