adjusting lock striker?
    once you crack it loose just do like 3/4 of a turn and then tap it in the direction you want it to go with a hammer. That makes sure that it stays relatively in place. Loosening it a ton will cause it to plop down to its lowest adjustment, and that's no good.
    It's not a big deal, just a piece of advice. Chances are you'll have a dirty outline of where the striker used to be once you move it so you can always work with that as a reference anyway.
      Originally posted by 91grandmarquis View Post
      WICKED
      Yep. You're from New England.
        My license plate reminds me every day! I forget that the term Wicked is a NE thing all the time though. Its bad when on vacation and people don't understand what it means in the context.
        1985 GMC 1500
          new englands totally wicked awesome dudeeee
          -Phil
            Originally posted by 1990LTD View Post
            gotcha. fuck that. my doors are never coming off of the hinges if i can help it
            You will. Eventually, the doors will sag, and that'll probably be from bad hinge pins, and if ignored long enough the door will cut into your trim, won't shut right, and leak.
              Had to do it to the olds, thats a two door car. Each door weighs like 100llbs (or it seems like it). Took about 3 hours to get everything aligned just right.
              I did a pair on a 75 Cutlass Supreme, yikes heck no not again.
              In the case of my 89, you have to be the Fonz to get the drivers door open
              Pete
                A pair of straps, an engine hoist, and an air hammer make short work of any hinge pin job, no matter how heavy the door.
                  floor jack and someone to hold the door upright also works. put a 2x4 between the jack and the door to prevent screwing up the paint, etc.
                    hinge pins arn't that bad!!! haha, john you are always so positive XD
                    -Phil
                      Having done it both ways, that's not even close to as insanely fucking awesome as using a hoist.
                        true... but I don't have a hoist. I do have a floor jack though.
                          You mean they'll go bad eventually? What are signs it's gone bad? It doesn't seem to close quite as tight closer to the hinge than at the rear of the door.
                            adjusted the striker...no big deal. i'm assuming there's no set position that is best for every car, you just have to adjust and check, adjust and check, adjust and check?
                              Your door wont shut right, youll have to lift it in place, and it will leak. If its really bad youll see it sagging, and you can feel it can move up and down when open. Youll know.
                              1985 GMC 1500
                                thanks j r
