I had to purchase the BWD unit locally. No one could find a Motorcraft unit as they appear to be discontinued and Green Sales wants your first born and virgin bride in payment for a NOS unit. I had no issues with using the BWD unit. RockAuto also offers a couple different brands. Side note, not much in these units to fetch such a high price. I've un-potted one of these and there are damn few components in them!
see if the connections to and from it are clean first. They usually don't go bad that often. I wouldn't expect a failure in 2 years. Connections are free to look at though.
many things, but really you need to find out if you have spark when it won't go. If you have good strong spark when it won't start, replacing the ignition box is probably not going to fix anything.
I've also had the issue that the connector on the TFI would slip off just enough to disconnect. That was highly annoying. Had to ziptie it on for a while so the clip would press down enough to hold it in.
I plan to drive it to the mechanic tomorrow morning, and if it dies on the way there I'll just have it towed like I was going to do anyways now that I have an AMA membership.
I'll forego the winterization and have him check the ignition module and the fuel pump and change the filter. Maybe I should idle the car and burn off the gas in the tank and refill it with 89 octane?
I've had my 88 run on damn near 85 octane... ran like crap, but never died on that tank. 11mpg on that crap, but it ran. I don't think the 87 octane is the issue.
