Fuel Pump or Carbeurator?
    Issues like that are harder to diagnose if it doesn't happen while the mechanic has it. I've seen stuff like that happen with bad fuel filters on various cars.
    '93 T-bird
    '03 Silverado ECSB
    Missed:
    '88 Mark VII
    '86 CV
      Well after nearly 2 weeks with no issues it did it again.
      It's about -16C outside and I put a tank of 89 octane it.
      I suspect that it is after all an electrical issue, specifically a combination of old spark plugs, the ignition module and the ignition coil.
      Replacing all 3 should fix the problem...
      If it doesn't, then, well hey, new parts.
        When this car runs, how smooth does it run? Does it feel smooth in gear?
