Sounds WORSE after Lucas Oil
    Originally posted by Southern_Pride View Post
    I'm over 320k with no knocking. Ya'll are doing it wrong.
    C'mon, you know how it is. People get some knockers to play with and it just turns into a fetish!
      Mine was pretty quiet with 200+K and 0 hot oil pressure....
        A good stereo is easier to install than a quiet motor. Turn it up and you won't hear that stupid bearing noise.
          Get louder exhaust
            LOL! That's what my neighbor says everytime I complain about a car noise
            Pete
              Originally posted by 1990LTD View Post
              Get louder exhaust
              also an option. Sawzalls are even easier to operate than a stereo.
                for shits and giggles tomorrow i am going to test the oil pressure and then change the oil with some lucas and test it again. testing oil pressure is part of a project at school and the shitmobile is due for an oil change.
                i kinda wanna verify that it's worth repairing before i start repairing it (needs lifters but i wanna know how tired it is)
                  Mine likes thinner oil; with anything more than 10w30, it's noisy except when it is fully warmed up (30+ minutes of driving.) This is on a car with very good oil pressure, and I'm pretty sure I have a damaged lifter that isn't pumping up properly.
                    lucas stuff
                    I've never used Lucas products,then again I don't put anything in the crankcase but Valvoline.
                    Back in the dark days of owning mopar 318's, I would put Restore in them, Restore seemed to get back a little compression and cut down on oil burning.
                    then again, what the hell do I know
                      I've used Restore in a few cars over the years. I've stopped the mosquito truck effect on one Toyota, regained compression on numerous vehicles (might should try that again in the 88... hmm...) But you should always use non-detergent oils when using Restore, that way it'll actually work. Once it's in there good, you can go back to using whatever oil you like. But I've only use the stuff on engines that are really worn out (or smoking).
                        You used the engine restorer??
                        How is that. I am debating whther or not to use that as a cleanser i guess
                        Originally posted by chitownvic View Post
                        Yeap.. my motor has about 145,000 on it and I just use Valvoline 10W40 and a Motorcraft Filter nutin fancy when I first got it I put a can of Restore in it and I think it was last year I put some HyperLube thick shit in it and it ran fine but otherwise she just gets straight oil
                        -1973 Volkswagen Bus Westy
                        -1986 Honda Magna 700cc
                        -2011 Subaru Outback
                          SEAFOAM in the oil?!?!?! never heard of that?
                          Originally posted by miamibob View Post
                          Seafoam just in the tank or also the oil?
                            Cleans out the engine somewhat BEFORE an oil change. Some folks may leave it in but I wouldn't.
                              I've used it in an old corolla that was smoking pretty bad. worked like a charm after about 1000 miles. stopped smoking. used it once in my 88 and it didn't seem to do much at all. What it does is fill up little scratches in the cylinder walls to reduce oil burning and improve compression. if the cylinder walls are fine... it won't do anything for ya.
                                Used Lucas fuel additive in the gas tank. It was the best thing that happened in the history of my GM.
                                IT CAUSED A ROD KNOCK a couple of weeks later!
                                Took that LOPO out and put a HO in.
                                THANK YOU LUCAS OIL!
                                I will never use your product or like products again.
                                Any comments on Risolene or Marvel Mystery oil?
                                Used them 25-30 years ago without issues.
                                I still use RESTORE on occasion in the 2003 Grand Caravan and in the 91 GM. I also use Slick 50 or Duralube every now and then in both vehicles.
                                Any comments on what weight oil to use in a 22 yearold car?
                                90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
                                90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
                                91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
                                70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
