Need help with 1987 5.0 in Town Car
    Hi. I was told to come here by a real nice guy from lincolnvscadillac.com. He said you guys may be able to help. Here's my problem.
    I have an 87 Lincoln Town Car that is a limo. I really need to get it running before Homecoming for my kids. Ok I have an 87 TC that is a limo. It had a bad coil so I replaced it. I was looking for vacuum leaks and ended up (dont ask) taking off the throttle position sensor. I put it back on and off we went. We made a couple stops and then put gas in and headed out of town. Got to town about 15 miles and it acted like it was out of gas and then died. Couldnt get it to stay running. Towed it back home and changed the fuel filter. It started up fine and good. Let it run for about a 30 minutes and went for a drive. Got about 2 miles and the same thing. Towed it again. Changed the filter again but this time it wouldnt start.
    So I figured I messed up the TPS. Put a new one on and it started. It takes several turns of the motor to start When it does it idles fine but you touch the gas and it stumbles and wants to die.
    Finally got the TPS adjusted properly and it will start but it takes a few tries before it takes. If you hit the throttle hard it stumbles and sometimes dies. I can get it in gear and it will stay running but if I go to move it will die. The thing smells real gassy too.
    Everything checks out. Gas pressure is 39, EGR appears to be working, there's no gas coming from the vacuum nozzles of the fuel regulator, the coolant sensor changes resistance with the temp of the coolant and the PCV rattles and the spring moves freely. I'm about to send it to the scrap yard but the kids love it.
    I've been to many forums and non have been able to help to resolve this. I'm kind of at my wits end with this. What would you fellas do if this was in your driveway? I would really REALLY appreciate any help I can get to get this beast running again. thanks
    jeremy
    One more thing. My dad ran the codes and all he said was that they were 53 and 34. I'm going to get the code reader myself and check it tomorrow. Also it does this regardless of being hot or cold. Exact same thing either way.
    Code 53 means your throttle position sensor is set too high. And code 34 comes up as a EVP EGR valve not responding both of which will give you those symptoms you just named. Also check the MAP sensor and the vacumn hoses running from it, they just might be pinched off under your intake manifold from the vacumn suction. Due to the age of the rubber vacumn hoses they sometimes collapse. Just my 2 cents. Also if the idle screw has been tampered with it needs to be set properly back to ford specs before you set the TPS if not you will never get it right
    sigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
      Thanks for the reply. The idle screw han't been touched as far as I know. It's got to be something simple and I'm sure it's right in front of my face. This just came on suddenly out of the blue.
      I did take the EGR off and cleaned it up. The diaphram holds and if I mess with it when running the car runs like crap.
      jeremy
        Make sure you use a new gasket for the EGR valve. Otherwise you'll end up with a HUGE vacuum leak there.
          As I found out a few months ago, a lot of problems with these EFI 5.0L engines affect the EGR system. When I ran the codes for a similar problem, it told me the EGR system was bad. I replaced everything for the EGR system and it turned out to be a bad fuel pump. Check your fuel pressure (if you got a fuel pressure guage) with the ignition on and engine off. Then start her up and check the pressure again.
            I have 39psi for the fuel pressure. I can get open the throttle on it pretty high but half the time it stumbles real bad when move the throttle. I'm at a loss.
              Ok I ran the coeds again myself this time. I did the test 3 times and I got:
              KOEO code 11
              KOER first scan was 12, 13 and 94. Last two was just 12
              Any ideas?
                Congratulations, your KOEO code, 11 means all systems OK.
                Code 12 is RPM at idle high
                Code 13 is RPM at idle low
                Code 94 is Air diverter solenoid circuit fault
                Did you ever find the Idle screw and figure out if it was set right?
                  Pull the iac off and clean it. That's the IAC code. It sounds like it's gummed up with oil and stuff. IAC is on the throttle body, behind the TPS. Cylindrical looking thing. 2 10mm bolts, use a new gasket.
                    12 and 13 at the same time is usually a bad IAC. I've only ever seen that happen once and it was with a new aftermarket IAC. A used Ford one fixed the problem.
                      There's nothing in the haynes book on it to find it. I'm not sure this car has one.
                        It should have one. it is on the throttle body. Like vicky said..the cylindrical looking thing.
                          Oh the BYC-ISC or something like that. I have it right here in front of me actually. I was cleaning it to see if it would help. I'll call see if I can get a new one.
                            Did you buy gas from a place you always use? If not, drain and refill from a known good station.
                            Check your fuel lines carefully. Given its a limo, theres line added, if it starts sucking air, your not going to go far. (cracked, rusted lines. loose, rotten hoses).
                            Alex.
                              ^why would the lines suck air if the fuel pump is in the gas tank?lol but, your right. its not a bad idea to check the fuel system and fuel filter.
