yeah... no spark signal from the TFI... looks like the computer may have taken out the TFI. the computer in there now is still holding to life so whatever damage was done was a one shot it looks like.
Engine computer died
Originally posted by 85crownHPP View Postsucks!!!!!!!! I wonder if the ECM blowing did other damage... I hope its not the other way around
also check the important wires for shorts to power/voltage.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
all the wires are good... grounds are secure... etc etc... bah.
replaced the TFI module. all better now. Hopefully it'll stay that way for the foreseeable future.
gonna take it for a drive after I scarf some lunch and see how it behaves.
drives right nice again. so engine computer and ignition module and it's all better.
A word to the wise: new TFI modules usually come with dielectric grease, but this is not what you want to use between the module and the distributor, since it doesn't conduct heat worth a shit. Use CPU thermal paste like you would between a CPU and a heatsink in your computer, and the TFI module will last much longer.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by 88grandmarq View PostI would say just the opposite, sounds to me like there is an electrical gremlin thats causing damage to various modules. check and re-check all your grounds.
I'd hardy call it a catastrophic meltdown. 20+ year old capacitors can fail at any time, and blow out the way this one did, without some outside source to cause the failure. Hell, brand new capacitors can do this if they are a shitty cheap brand. Old capacitors in general are a ticking time bomb.
amazingly enough, the module I got came with thermal silicon grease (the white crap) instead of dielectric grease (the semi-clear goop). car runs fine now.
Hi Slymer
Two electronic components dying in quick succession; it might be worth checking your alternator isn't over charging.
Regards
DereckPresident and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
it's definitely NOT overcharging... undercharging it does do. I get MAX about 14 volts. I'm planning on a 3g conversion by thanksgiving.
the rectifiers in it aren't shot are they? I've seen alternators fail in a way that puts AC in the system. Stuff doesn't like that much.86 Lincoln Town Car (Galactica).
just a 0.1V ripple. That should be fine.
how do you test for this???Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
oscilloscope set on AC with 0.1v/div vertical and 0.1sec/div horizontal with a DMM set on AC in parallel to confirm, with the leads across the battery (output from alt to ground).
The oscilloscope is there to watch for spikes. Didn't have any after I got the leads connected good.
