Is there anything left to do on my HO?
    So I have this lo-po converted to HO, and its been my understanding that it the pistons in this motor will not accept a more aggressive cam than .500 and it will not accept any heads with valves bigger than the E7's. I'd like to put some AFR heads on that add 100 horsepower like in the books, or at least some GT40's for an extra 40 horsepower or something. Any options for big power adders without changing pistons?
    personally I would concentrate on the rest of the car. rebuild the front end, do a big brake swap, do gears and a rear disc conversion, upgrade the transmission. then worry about more power from the engine. some transmission improvements and more gear will make the car considerably quicker with out doing anything else to the motor.
      He's right. Those parts would make it a lot more predictable and reliable, as well.
        What they said. The rest of the drivetrain should be optimized to get the most out of the power you have. Once you start going past the factory parts, tuning becomes an issue and is expensive.
          Mike knows that first hand and he still hasn't even made it past the factory parts!
            The important part isn't factory (cam)...regardless, to get the most out of the motor with mods, it needs to be tuned. I miss my "stock" HO conversion. That POS ran like a top.
              Gears and brakes are a good thing. Gotta be able to stop before you can go.
                Yeah my brakes in the rear are ORIGINIAL drums, only new pads in the front. I took it in and they said the rear drums had plenty of life left in them, and that they just needed adjusting. Got new shocks 3 months ago. I would like a 3.55 posi, and my transmission is all stock never touched. How hard is a rear disc conversion?
                  I heard the rear disc conversion isn't hard. I would've done if I hadn't sold my car. Scott knows all about it, he'll tell you what you need to know.
                    the rear disc conversion is easy
                    you need to remove the axles, unbolt the drum setup and remove the e-brake cables, and bolt up the rear disc setup, hook up the fluid lines to the hoses and make some simple brackets, and hook up the rear disc emergency brake cables
                      Why would you need to remove the axles to do that?
                        so you can remove the backing plates mang
                          Ahhh...just curious.
                            Rear gears are fun. A stock HO in a big Crown Vic with 4.10 gears will pull to 'fun' levels...but yeah, I'm feeling your desire to squeak out a bit more. At this point, I'd go with the rest and say focus on improving some bits of the car and save up for a better engine if you're serious with it. An HO can only go so far in a big car...
                            ~Adam
                            '85 2-Door Crown Victoria
                            302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
                            '04 Crown Victoria LX Sport, '02 Jeep Liberty
                            '83 Suzuki GS 1100E Motorcycle[/color]
                              ho in a big car......my car and fordgirls car kick ass.....the vic is a freak as it has all stock unmodified parts
                              big cars rawk......let the panther power move you
