Ho's can do alot in a big car. If you match everything well. Even a lopo can, if you use the power it has well. 16.03 in the 1/4 for my lopo.
Is there anything left to do on my HO?
3.55's or 3.73's and a high-rev governer would be your best bet for a little extra snap. After that, maybe add some 1.7 RR'sNick
88 Colony Park LS
uhh i didnt read this whole thread to see if anyone else posted this... and sorry i
cant find the article but i'm sure u can google it but afr is having serious head problems right now i wouldnt get any!Sellin off toys... need money for the dodge!
i dont know what everyones fascination is with aluminium heads.....give me ported cast iron heads anyday...........remember the ford 3.8 v6?.........tune up and head gaskets every 60,000 mi like clockwork lol
tuning is easy with an Apexi S-AFC air/fuel ratio controller. for about 299 you can adjust your fuel pressure/air ratio to whatever it needs to be, provided you have big enough injectors and a powerful enough fuel pump. [It has its limits though] I still don't get how they got 400hp out of a stock 5.0 HO with only AFR heads and 1.7 RR....was that motor carbed?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by lincolnmaniaremember the ford 3.8 v6?1990 Country Squire - under restoration
Originally posted by TiggieMost people that had problems had problems because they didn't run the specially formulated Antifreeze Ford recommended specifically for the 3.8L, and didn't change it religiously like Ford recommended.86 Lincoln Town Car (Galactica).
