Do I have to make any fine adjustments to a new TPS for my '86 GM with 5.0? after I install same?
Throttle Position Sensor.
Not really. You can confirm that the voltage output is somewhere around 1 volt, but its intended to not really be adjustable.86 Lincoln Town Car (Galactica).
ideally black wire in the TPS harness should be your ground but you got the idea. There is a potential for slightly different ground potential between the TPS circuit ground and the engine block. Not significant, but when you're talking about 1 volt, a couple tenths can screw your readings up.86 Lincoln Town Car (Galactica).
Normal acceptable range is I think 0.8 - 1.1v, normally its somewhere in the 0.9-1.0v range. If its outside that range, its toast. The other trick is that the voltage needs to smoothly increase from idle to WOT without any drops or spikes.86 Lincoln Town Car (Galactica).
yes. Its usually easier to see that sort of thing with an analog voltmeter but usually when they die, it'll be at or near the bottom end of the throttle range where it acts up. You'll also typically get a code about it stored.86 Lincoln Town Car (Galactica).
if you sweep it and it doesn't change... toss it. If that's the idle position... that's about right.
That reading was key on engine off. Did not do a reading from idle to wot.
The problem is that the car stumbles when cold, and when I feed gas, it does not react immediately, it sorta jerks up and back..until I really put my foot into the gas........delayed acceleration.
See if it sweeps with the engine not running. If it does, the TPS is fine.
Try unhooking the EGR vacuum line to see if anything changes. If it runs better, clean the EGR vacuum regulator filter and shoot some WD40 down the hole under the filter to see if it helps any.86 Lincoln Town Car (Galactica).
key on engine off will give the signal. you want the engine off because you don't want to rev the nuts off of it.
