Intellitronix Gauges in a box Vic? (86)
    Nice!
    Somone probably has a pinout for the ECM around here. If I can find some time I could probably piece it together going off my '89 and '91 EVTMs.
    That would be for a stock ECM. Aren't you putting something non stock in?
    Vic
      Originally posted by DrHax View Post
      What do you guys think?
      I like it.
        Looks very nice.
          Ds9 I think. It's for the HO swap that I stumbled into. Begrudgingly upgrading... due to purchasing the wrong year f150 motor.
            Here is some info that should help with that:
            http://www.grandmarq.net/oldfuelinje...0Lpinouts.html
            The column with '86-'91 CV Speed Density looks like it might be for '86 (missing all speed control). Also compared to my '91 EVTM Pins 44 and 53 are unused for '91, but I think it's exactly what you need to know about your stock setup.
            The column for '86-'92 Mark VII Speed Density is what you would need for a D9S. A quick copy and paste of the entire table from the link above to an Excel spreadsheet (hide the columns between the two you care about) and it seems that you don't need to make any wiring changes.
            Also a list of EEC modules: http://www.cb4x4.com/PDFs/Engine%20-...am%20Codes.pdf
            No DS9 listed, so I'm assuming D9S is what you have. If it's not a D9S, you might need to ignore the above info, although the link will probably still be useful.
            Vic
              Now I'm curious about that chart. I
              Would like to see about wiring the tach to the EEC since then the wires would go to the same place. Saving me on wire lol.
                Not sure if the tach would be happy picking up the signal after the 22K Ohm resistor.
                Ignition diagram for reference:
                Where the 22K Ohm resistor lives varies by make and/or model year. If you cut the 22K Ohm resistor out and replace it with wire then move the resistor closer to pin 4 of the EEC, you wouldn't have to run the tach wire as far. EEC would still get its signal after the resistor, but that's a lot of extra work if you ask me.
                Vic
                  That cluster is purty cool. If anyone is interested I have a running and driving '91 Mark VII that is for sale for cheap. I doubt I'll ever do the swap.
                    Okay I feel stupid but where is the EEC located?
                      I found it. I got the plug off and I am having troubles figuring out which wire i should tap into for the VSS the plug has a few labels on it. There's a wire beside a number 1 under a a set of two wires by a 20, yet on the opposite side is a label stating 21.
                      How do I figure out which wire is which?
                        Okay I went outside and took a picture of the plug. Annoyingly its sideways, but it appears the car doesn't use wire three on the eec.. or am I misreading the plug. http://www.grandmarq.net/oldfuelinje...ages/eec04.gif
                        That is what I found which I am using as a reference.
                        Now non of this makes sense in correlation to the data sheets. There's no metal contact for pin three apparently or six.. the only pins used in that row are 1, 4,7 10.
                        Umm can any EEC experts shine some light on this?
                        Turns out the Lincoln speed density eec doesn't even have those pins used after comparing the charts. Looks like VSS from the eec isn't even used. So now where do I tap this from if there's no VSS via The EEC. Where are the VSS wires going? Time to consult my manuals.
                          You are looking at it right. 1, 4, 7, and 10 being the only used pins on that upper left makes sense. 3 must not be used since the cruise control is stand alone on your '86 and the Mark VII; pin 3 would only have VSS signal to it if the cruise was integrated.
                          For VSS signal, I would think that the shortest distance to tap would be whatever controls cruise on your '86. Since I have no experience with that setup and don't have an '86 EVTM, I have no idea where that would be.
                          Vic
                            For verification... I marked pin 1 on your pic.
                              Also, for VSS signal, you can use the 3-wire connector under the dash for the cruise control that has a black and green/white wire. Tap the green/white wire for the VSS signal.
                              for picture references... check this thread... http://www.grandmarq.net/vb/showthre...r-installation.
                                So that module by the brake pedal I mistakenly took for the ECM is in fact the cruise control. thats mighty convenient, good so I know what to look for!
