EJ Err - '05 Marquis LS
    Halp! My AC/DC cd is stuck in my player. I'm not even sure what sort it is...I think it's a 6 cd changer, but I can't find any slots other than the single CD slot...which, when I press eject says "EJ Err" or "No CD".
    Would a batt cable disconnect fix this?
    A battery cable disconnect might work, but I doubt it.
    In fact you can just pull the unit out of the dash and unplug it.
    I think you'll have to dig it out.
    I would try taking the unit in the house and removing the front cover.
    That will give you more room to work with.
    If it still doesn't come out I would try plugging it back in with the face plate still off.
    And go at it that way, hitting the eject button every now and then until it comes out.
    I've gotten them out doing this but it's not a sure thing.
    You may have to take the radio almost totally apart to get to the CD.
    Good Luck!
      If you can select the disc (disc up and down buttons) you might be able to get it to play... once you get there, you may be able to eject it with a battery disconnect (or pulling the head out of the dash and unplugging and re-plugging the harness). If that doesn't work, yeah... gonna have to rip it apart to get the disc out.
        No go on the batt disconnect or switching CD's (which, how do I load more than one?)...it will read and play the CD, but won't pop it out.
          Nothing wrong with AC/DC taking up permanent residence in a CD player.
            then yeah... gonna have to rip it apart to get the cd out. sounds like the eject motor took a dump.
