Fan will only work on HI setting
    I replaced all three of the switches on my ATC unit on my 89 crown vic and I thought before hand that the blower motor switch went bad so I replaced it. I just put the whole thing back together today and it didn't work. I need help because I have worked on this dam car for four hours and this happens...oh and I also tapped on the blower motor itself and that didn't change a thing. Im thinking that my ATC is screwing everything up but I just want to make sure before I go any further with anything else. I ALSO THOUGHT TO BELIEVE THAT THE SENSOR RELAY SWITCH WENT BAD but I have no idea where it is and what it looks like. My father mentioned that to me before I replaced all of the switches.
    Proud owner of a 1989 Crown Victoria LX LTD
    • Restored The Car Back To Running Conidition
    • Has a very well respected and cared for 107K miles on the odometer
    • Rebuilt 4 speed AOD Transmission *Original Trans Still in Car*
    • Rebuilt Front End with New Hub Assembly
    • 3rd Owner (Car has been in the family since 91)
    • They don't make cars like this anymore so it will be a definite keeper!
    Sounds like the blower resistor or the plug is shot. The switches aren't all that problematic. The resistor lives in the plenum, straight behind the valve cover on the passenger side. Find the big electrical plug back there, and you've got it. Unplug it and clean the connector first since that might fix it. If not, the resistor holds in with 2 screws I think.
      well I did find it and uhhhmm... the thing scorched the wiring harness and plug, along with itself... so got both parts ordered and I should be a happy camper in a week or two
        yea those things get hot and melt the plug
          Would I be expecting to replace it again in the future?
            Not really, it lasted the first 25 years.
              They get hot when the connection corrodes. The corrosion causes resistance, which makes heat. If you put some dielectric grease on there to help seal out moisture, it should last another 25 years without much trouble.
                ok thank you for the advice. Ill put some on when I get it all hooked up
                  yeah.. BTDT... see attached pics of what mine did.
                    Nice and toasty...
                      you know, I've never touched mine. It is one of a few things I've not had to deal with. I'm frankly terrified of trying to unplug it. I expect the whole connector will turn to dust in my hands if I try.
                        Hey that looks like mine!!
                          lol yeah. I accidentally unplugged mine trying to get access to it. I thought "Wow this is finally going to be easy for once" Then I looked at the plug and the resistor and that's when I called it a day.
