anyone have a pic of the rear seatbelt mounting on a 98+?
    Hey all, today I removed the plastic police criminal seat in back and bolted in an 09 rear seat. The seat was a perfect fit, but the seatbelts are off slightly .
    I've got the left and right shoulder belts figured out, but the middle seatbelt seems kinda weird (I don't have one, but there is just a bracket.
    if anyone has their seat out and can take or has a picture of the rear floorboard seatbelt mounting that would be perfect!
    -1999 P71 Crown vic X LAPD..
    -1966 mustang, 5.0 roller crate motor, t5 etc
    -1972 maverick 5.0 roller crate motor with EFI and a Lentech AOD
    The belt for the middle should attach to the same spot as the buckle the drivers side seat belt. And the buckle for the center seat should be attached to the same mounting point as the buckle for the passenger side.
    Good enough? Or do you still need pics?
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      thanks ryan...that makes sense. I've got a weird extender bracket and i wasn't sure if it was part of the plastic seat setup/....now I know it is. all I have to do is pick up some middle seat belts from somewhere now...thanks!
        No Prob!
        I have to pop my rear seat cushion out every time I haul my DJ speakers around. If the cushion is in, they don't fit.
        So I've done the remove, reinstall, remove, reinstall and bunch of times.
        Good luck!
        (I believe you'll need a 18mm socket. 1/2" drive is the best)
