Ok, I have noticed that when the speedometer starts to move, and continues to move, I hear squeaking, constant squeaking, it gets faster the higher the speed, so I think it's the speedometer, or the speedometer cable, is there anything I can use to lubricate the speedometer or speedometer cable to stop it from squeaking? It's really annoying.
Squeaky Speedometer
try a new cable first.....should be under 20 bucks for a brandy new one
most likely its the speedo cable. You can pull the cable loose from the back of the cluster and lubricate it, but that usually doesnt last long.
I think you can still get speedo cables from Ford, just replace the cable.Last edited by 88grandmarq; 10-11-2008, 03:45 PM.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Ive had the cable almost all the way apart john, if you need help with part of the process ill gladly help you-Phil
When the car's been warmed up (heat on full), or during the warmer months it'll be fairly quiet. On a cold morning in February, it'll sound like a hampster wheel. So long as it works, I wouldn't worry about it to much. I want to rebuild my speedo and get a new cable down the line for mine so that's something you might want to plan for in the future as well.sigpic
1986 Grand Marquis LS 2 Door
Originally posted by 86GmLsCoupe View PostWhen the car's been warmed up (heat on full), or during the warmer months it'll be fairly quiet. On a cold morning in February, it'll sound like a hampster wheel. So long as it works, I wouldn't worry about it to much. I want to rebuild my speedo and get a new cable down the line for mine so that's something you might want to plan for in the future as well.
Yep, I've been starting to stock up on harder to find parts when my budget allows. That cable is going on the list.sigpic
Originally posted by turbo2256b View PostHave the same issue with Creams at low speed when its cold out until the car warms up. Ford manual talks about applying some special non conducting grease at the connection end to the speedo. Did it possibly helped some not sure.
