How do i change out my headlight switch on my 89 MGM? Also right now i have auto headlights can i put in a non auto headlight switch? Saving $20 is a good idea to me excpecially since i always use my headlights manual'y
changing headlight switch
The way I do it...take out the screws holding the dash trim around the speedo area. Pull out the headlight knob and un screw the autolight adjuster part. Put the e-brake on, turn the key, pull the shifter down. Pull out the dash trim and bring it up and over toward the driver door...this will reveal 2 screws holding the headlight switch in...get those out and keep moving the trim panel until you can get the other 2 out. Headlight switch comes out, push the button to release the knob and viola.
Now, the right way is to sneek your hand up behind there and push the lil button to release the knob. Then you don't have to manuever the dash trim around. I never could get my big hands in there tho. Crown Vics are different tho, ya kinda have too.'89 Ford LTD Crown Vic - '92 Ford F-150 Custom -
'95 Ford Bronco XL -
sigpic :rebel:
well Im preety sure its the headlight switch thats no good. One day driving home. I had highbeams on those flickered for a bit than stopped working. Next day i didnt even have low beams. all other lights work, parking light's, taillight's.
But no headlights all the lights will go on if i hold the high beam but once i let go its all dead again1999 CVPI
Old Rides
1988 Ford Mustang GT (trickflow stage 1)
1989 Mercury Grand Marquis LS (5.SLO)
1989 Ford Thunderbird SC (3.8 Supacharged)
yeah mine was the same way just the parking lights would work the way I did it was potting my hand up through the dash grandmarq's are a lot eaiser then vic's the way I did it was take the bottom kick panel out. you have to get your hand in their feel your way around. you have to push that little button to make the shaft go out. then take the max delay knob out. then un screw the switch from the dash the take the connectors out. then there you go. I got my headlight switch from the junk yard for 5.00 it still works good too lol
