Originally posted by sly
View Post
My 1983 Continental Mark VI!
yep. melt out the goo with contact cleaner and maybe take a small pokey tool in there and give it a slight scrape to get rid of any crust. I've had problems with ancient connector grease turning into glue before. At that point it needs to go away. Put a bit of fresh spark plug grease in there and it should be happy again.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postyep. melt out the goo with contact cleaner and maybe take a small pokey tool in there and give it a slight scrape to get rid of any crust. I've had problems with ancient connector grease turning into glue before. At that point it needs to go away. Put a bit of fresh spark plug grease in there and it should be happy again.
+1 just hose it. Also, a firm toothbrush works great as a parts cleaner brush. I have some in my collection for cleaning electronics.
Originally posted by sly View Post+1 just hose it. Also, a firm toothbrush works great as a parts cleaner brush. I have some in my collection for cleaning electronics.
Originally posted by mercurygm88 View PostHmm...... I might be getting somewhere. Just after my last post I ran into town to grab some stuff from the gas station. The car didn't want to start, I pulled the key out of the ignition and put it back in and removed it several times, tried it again and it fired right up. Coincidence? Anything in the lock cylinder that could potentially cause this no start issue? I realize this is not a chipped key or anything, I don't even know if there are electrical contacts for the lock cylinder. I notice you have to get the key angled just right or it only goes about halfway in. Perhaps something with the ignition switch?
only thing that contact in the cylinder does is make the door chime ring when the keys are in the ignition and the door is open. Won't bother how it starts or runs.86 Lincoln Town Car (Galactica).
Also, they're not hard to re-pin. I just swapped the pins from my old one over to the new one. Still using the original keys. The pins weren't worn much at all.
Originally posted by DerekTheGreat View PostReminds me, I remember my '85 would start nearly instantly too. Makes me think they program a delay into most cars, maybe for oiling reasons?
All the SEFI/EFI stuff waits for the offset pin on whatever sensor they get timing from. Some require one rotation of the engine (crank sensor) the rest require 2 (cam/dizzy sensor). So if the fuel pressure is good, one to two turns of the crank should get it to start firing. "Should".
^^ this, engine has to spin far enough to know what cylinder is coming up. 4.6 cars have a crank position sensor so it requires less than 1 rotation for an ID, 5.0 cars do this from the distributor so it can be up to 2 rotations.
CFI cars don't care what cylinder is coming up, its batch fire so it just sprays one injector or the other. I expect the trucks would also light off quicker for the same reason.86 Lincoln Town Car (Galactica).
