My 85' Crown Vic
    Ive replaced both racks and boxes (at work) and unfortunately you're right. I just hope I get more than a year out of this one.
      Same goes for A/C compressors too.
        The aftermath
          Nice. Been there before:
            After replacing the body bushings I added "ditch" lights. Here are the results.Click image for larger version
ID:	1289675Click image for larger version
              Lights look good
                thanks!
                  Don't thank me
                  thank yourself
                  you're the one who installed them lol
                    Just now came across your thread and I gotta say, WOW! I really like it. Im jealous of the pinstripe, mine is basically gone. Great work with the body bushings and all the steering stuff as well. I love the speedo! Really cool car. I'm glad to see a CV version two door out on the road, and in great condition to boot!
                    1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own the fastest CFI powered box to the 1/8th mile: 9.658@70.74mph
                    1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Forged Pistons, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, Jegs Built AOD, Roadrunner 3000 Stall Converter, Ford Racing 4.10 Gear - Best 1/8th mile time: 9.76@72.03
                      I found an NOS FS6 compressor cheap and have it on the shelf as a spare for the Towncar and the Conti. Been down the reman path. The one on the Townie sounds like a dying air raid siren. The one it replaced lasted about a year before losing it's seals. The used original 1986 compressor I stuck on the Conti is perfectly quiet and works fantastic.
                        Ditch lights are awesome. One of my cues for a higher optioned vehicle.
                        That's just so sad, that searching for NOS parts is what we're reduced to. I *think* there was a time when remanned stuff wasn't complete shit.
                          approaching the point where I'm willing to do my own reman work. If its going to be a piece of shit, at least it won't be an expensive piece of shit.
                            LOL.
                            I think remans have dropped in quality but I'm not so sure old remans were that good either. I'm guilty of turning in the worst core that probably isn't going to be rebuildable. I bet I'm not the only one. The parts store folk don't seem to care any more.
                              I saw a post from a year or two ago you made about using Eastern Catalytic part number 30205 for the driver’s side cat replacement. Did this work ok with the heat riser valve?
                                I still havent put the cats on yet, so i cant say.
