I call it the Monolith. I have plans for it.
    Alright, looks like I might get some use out of those bimetal sawzall blades after all.
    I'm not sure how confident I would be in getting it installed without a rebuild, because the reason my current one is borked is I flushed it, which cleaned out the grime that was keeping it functioning. So I'm sure you can understand why I'd be nervous about it. I mean, I guess I'd have another one I could rebuild if it happened again, but that's at least half a grand down the shitter, assuming I also removed my own.
    What does the bushing indicate that implies it would be acceptable? Just general abuse, or is it more specific?
    With the Lincoln, is it the entire case that's longer, or just the extension housing? Cause for some reason there's a short extension housing just sitting there inside the car.
    Wow, you guys are fast. Thank you.
    89 Grand Marquis GS.
    Putting it here because I keep forgetting to mention it. It's not very exciting at the moment.
      Lincoln is longer in the tail shaft and housing. You'd have to replace the tail shaft and the tail shaft housing to make it fit properly. And if you're that far into the trans, might as well replace all the broken bits along the way since you've got to take EVERYTHING out to get to the tail shaft.
        I see, that makes sense. The Town Car is longer, and that's easier to do.
        Theoretically, you could probably shorten the driveshaft instead, I think. Assuming that doesn't completely screw up the angle. That's still more effort, but more doable if it comes to that.
        Are there any other ways to tell if I would be safe without a rebuild?
        EDIT: Obviously the dipstick and pan, chucklenuts.
        It should be noted that I am still recovering from two consecutive concussions. On the second one, I passed out, fell backwards and hit the concrete floor so hard that when my jaw slammed shut, it dislocated and chipped two of my teeth just from sheer inertia. Have to regularly relocate my jaw now, because it won't stay aligned. Sometimes I forget where I am for a second, and my short term memory has taken off to run a tech startup in New Jersey.
        Anyway.
        So the real question is how much oil I will have to deal with if I drop the pan. Doesn't look like it has a drain plug.
          Even one that looks mint on the outside may not work. No real way to know if a trans will work until you put it in gear without taking it apart.
          Pan drop... 4-5 quarts. Complete refill is 14 quarts. VB out, 10-11 quarts.
            3 and a half gallons. Wow.
            I figured as much. One one hand, most original owners of these wouldn't be driving them very hard. On the other hand, they statistically also wouldn't have a clue how to maintain them. Granted, the previous owner of mine was NOT nice to it, and neither was I in the grand scheme of things, but still.
            I should probably rebuild it anyway, just to be safe. Not looking forward to that either, especially since my only workshop is my own studio apartment.
            What are the odds of this thing crushing me to death when I get it loose? That's about 200 pounds of metal and oil, all the cars are lifted using old wheels, and the yard doesn't allow jacks. I don't know if that also applies to transmission jacks; I forgot to ask. Worst case, I guess I could borrow an old mattress. In any case, I'm not going to get very far if I end up in the hospital or something.
              If it were me (I am disabled) I would not mess with pulling a transmission that you really don't know what shape it is in. You could pull the inspection plate and look at the torque converter. If it has been replaced, chances are it is painted. That still doesn't insure the trans is good. A better and safer choice would be to buy one already pulled or can be pulled by a wrecking yard. You should get at minimum a 30 day warranty. I would not buy one unless it is for 90 days. You might spend a bit more money. How much money would you be out if you got hurt or the trans was junk?
                If you weren't so far away I'd sell you my old trans cheap, I can guarantee it'll work well. If you do have to pull it in the yard, get as much fluid out at you can first
                -Phil
                  It will crush you. It is very heavy especially in an awkward position like under the car on dirt with little access.
                  Id say pull some rear seats and use those to soften the fall of the transmission once you have everything unbolted and try to pull it from the rear and have it drop onto the seat bottoms. Then drag the sucker out.
                  Id say best bet is to grab a rental or if you have another vehicle to handle the transmission and drive to Phil and get the sure thing. Sure it is like 10 plus hours one way but you are getting the sure thing.
                    If you are by some chance seriously considering it, PM me and I can give you more details on the trans. I could always drive a couple hours west to lessen your total trip
                    -Phil
                      Would some small jacks (hydraulic) under the trany help? I haven't checked this entire thread but is a rebuild of your current trany out as a possibility?
                        What I did when I pulled the AOD in favor of the T5Z was build a wooden cradle that bolted to the floor jack and fit around the transmission pan. Made things easier on a paved driveway.
                          Sorry it's been so long without a response. Depression has been slowly dissolving my soul.
                          I was planning on rebuilding it after I removed it. I have all the tech manuals, and they're really well written. As for money: If I was hurt, no idea. That happens all the time. If the trans is junk, they charge $200.
                          I...will seriously consider that. That very well could save me. New freakin Jersey, though... The logistics of that would probably defeat the point, wouldn't it?
                          Well I already pulled the back seat, but that's because I'm keeping it, lol. I could grab some trashed leather seats out of a Vic or something. I was going to support it with bungee cords, but that would also help.
                          I have another car I've been driving. 03 Sentra, it was my grandma's. I don't really hate it, but I call it the Maximum Shitbox for a reason. It's currently three different colors. I'll leave how that happened up to your imagination.
                          I dunno. It would beat the hell out of freezing my ass off for two days and spending god-knows-how-long rebuilding it myself, but that's 3 days minimum, unless I'm missing something.
                          The yard doesn't allow jacks, including transmission jacks. Rebuilding the current one isn't completely out of the question, but I'm not allowed to work on it in the parking lot, so I need somewhere else to take it, and I don't have anywhere. I am almost completely alone in this endeavor. In all endeavors, really.
                          I was at the yard a couple weeks ago. I got myself:
                          Back seat
                          Rear cover
                          Rear speakers
                          Front door panels
                          Front speakers
                          Rear door trim
                          Window motor
                          And all relevant hardware that I could find. Which is saying a lot, because the door panels are held on with twenty-five screws.
                          The seat is in much, much better condition, and I got some replacements for scuffed trim pieces.
                          Will I be able to bolt all the speakers directly in? The tech manuals don't have any clear answers for me. I would imagine they would use a single body style and just change what they put in it, but I can't be sure.
                          I also have a couple 6x9 three-way speakers I found a while back. Would those be usable in the rear, or am I stuck with the originals? I know exactly nothing about sound systems.
                          Also, I need a driver's door window. Every matching vehicle they have has a busted driver's window. I strongly doubt I could use the passenger window instead. Are there any obscure matches I'm unaware of?
                            I just HAD to say it, didn't I
                            I got all geared up to head to the junkard, aaaaaaaaand it won't start.
                            There is absolutely no reason it shouldn't start. Fuel pump is new and clearly working, plugs are new, coils are new, air filter is clean, it has power, it cranks...then I pulled the dipstick, and the oil is burnt. It was clean synthetic the last time I checked it. It's not black; the original color is there, but it's clearly charred. Coolant temperature was always fine, so at this point all I can deduce is the oil pump failed and she's done.
                              engines dont need oil pumps to start. If it wasn't pumping the idiot lights would be on anyway. No oil pump won't give you burned oil either, it'll just make sparkles and lock the engine up in a very short amount of time. Probably just getting old, or maybe the engine is running hot.
                              If its got fuel and compression, it has to be no spark. Pull a plug and verify. Know nothing about Sentras but if its got coil packs, fair bet it drives them from a crank or cam position sensor, and if one of those failed it won't go.
                                There may be EGR stuck open preventing it from running. Not sure of the configuration on that car though.
