    Undercoated the rest of the wheel wells today, which were the rears. Each wheel well took a can of Professional Grade Undercoating. I also undercoated the front floor boards with the professional stuff, two cans. The rest of the entire underside was hit with economical undercoating (basically no sound deadening properties) which took 5 cans. My face is black as well as my hands. lol
    Also purchased a quick spray detailer, micro fiber towels, chamois, and a brush for my wheels since these Durast pads are crap. I wanted to purchase the shock bolt kit but one of the only two there had pieces missing from it so I will try and reuse the existing hardware.
      Oh I also replaced a tire valve stem in my left front tire. The stem was all cracked and when bent it would leak air out, but left alone it was holding air just fine. All I did was remove the tire, put on the spare, laid the tire underneath the rear bumper and used the factory bumper jack to pop the bead. Snuck my hand in the tire to cut the bulb off and then pulled in a new valve stem. And filled with air to get the bead to seal again.
        Threw the rear springs in today along with damaged shocks...they were damaged in shipping
        Looks like 20+ year old stock saggy springs atm. Hope lowering the front will make it all look better. A little worried....
        before with wagon cargo coils
        After with stock front and lowered rear
        The upper bolts were a bit of a pain..But soaking them in some MOPAR spray as well as utilizing a ratchet wrench made things easier. The lowers zipped right off with the impact gun and I was able to reuse the stock hardware no problem.
        The old...
          just how damaged is damaged? small dent in the side? big dent? where on it is the damage? Pics? Complained to the shipper yet?
            Dents in the side that prevent the shock from compressing and expanding freely. No biggie as the seller said the problem will be rectified so I have no reason to worry yet.
            I am not to concerned as my mechanic (dad) said that it should be okay. Was only pissed that they arrived damaged after I seen pics of them in good shape from seller.
              That looks alots better now...perfect.
              1991 Mercury Grand Marquis LS - Current - June 2016 POTM Winner
              1996 Mercury Grand Marquis LS - SOLD
              1991 Mercury Grand Marquis LS - SOLD
              1987 Mercury Grand Marquis LS 2dr - Long gone
                yeah... the upper shrouds aren't a problem as long as the shock will compress and release freely. a little rubbing shouldn't be an issue. if it was a dent in the cylinder... then there would be issues.
                  It sits level. I like it.
                    Really that looks level?? Maybe I was so used to the skyjacker look that this just looks so different lol It feels as if I am leaning back in the car. Not to fond of the reverse rake. I really hope the fronts drop a good bit. Otherwise I predict myself purchasing new non squashed rear isolators as well as cutting a bit of coil on the fronts.
                      looks like it still has an inch of rake (front lower). Check the curb under the car in that last pic.
                        it does sit level. GMGT will look sweet when i do the spring swap in the rear too. and will look sweet with the 255s in the rear. do you feel much difference in ride quality in the rear?
                          I just backed it out of the back yard into my spot in the street so I dont have much drive time at all.
                          I wanna get an overall one time feel once the front springs and shocks as well as new end links and sway bar bushings are installed...but it looks as if they wont be installed for a while so I will let you know next week.
                          And I guess my mind is just used to the rear end being much higher.
                            Dave, I liked the old rake, i'm rooting for the front drop as well...will look mean with those bullets
                            -Phil
                              Lose the mudflaps, as mudflaps belong on a truck. If you're trying to protect the lower fender areas behind the tires...that's what the stainless trim does. Otherwise....it's really developing a redneck look to it with the extra chrome/stainless 'goodies'.
                              It's almost sitting correctly, drive it and see if it squishes down a bit up front....otherwise, the rear is almost perfect (maybe an inch lower?), the front needs another inch or two....and that's about it.
                              So far as the shocks are concerned....I would have bought the Police KYB's, personally. The one wagon I ran those shocks on didn't have much of a change from the turd Sensatracs that I yanked off of it in anger.
                                I have the same springs as you and ended up having to cut a half coil off the front the make it sit right. I was nervous at first but it was defiantly worth it.
                                1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
