These 'new' or remaned?
Advertised as new. I stay away from rebuilt as often as I can.~David~
Plus it looks like photobucket will no longer offer free third party hosting. There goes my years of photos.~David~
I had one reman and a couple different new ones. Much as I don't want to, it makes me consider rebuilding the damn things myself.86 Lincoln Town Car (Galactica).
I got a reman at a swap meet for $5, eight years and 50k ago. Works good. Probably the last of the good ones before they started cheaping out the newer remans.1990 Country Squire - under restoration
Air conditioning was still working fine, though I noticed the compressor was short cycling probably due to being low on refrigerant. Had a bottle of R12 around, same one I used back in either 2009/10 when the system was last topped off. I have a 134r fitting on my low side as the original fitting would no longer seal! So dad and I cobbled up a r12 t 134 adapter hose to use and fill up the system. the first time we just use regular r12 fittings to the car but like I said it began leaking after that.
After the AC was topped off (just cracked the bottle a bit and let the compressor's clutch stay engaged longer and closed her off) I used a can of meguiars air re freshener on her to make it smell extra nice inside.~David~
Need you a proper set of manifold gauges to do that kind of thing. R12/R22 ones show up used for relatively small money now that those are being phased out. R22 still exists but mostly older home AC equipment.86 Lincoln Town Car (Galactica).
True. I would be interested in seeing how things are reading.
Only have a 134 manifold set here. Could have cobbled up a way to make that set work but I did not want to mix any r12 in the 134 lines.~David~
noice! (spelling intentional)
Is it new?
I thought they were out of production.
Originally posted by sly View Postnoice! (spelling intentional)
Originally posted by mitymerc View PostIs it new?
I thought they were out of production.~David~
I don't believe mine came with belt sizing info. Maybe a change, or perhaps I just missed the sheet.86 Lincoln Town Car (Galactica).
Awesome, another custom part for a seriously customized car!
Do you mean it is available in NFG?
Let us know how it it charges & cools.
I'd hope its not available in NFG. That would be pointless.86 Lincoln Town Car (Galactica).
