    Originally posted by RustyRodder View Post
    whats the difference from that and the one you're selling? they look the same
    Old:
    New:
    Mine now has a nice smooth shot going into the tb and the air box is a bit bigger and has a bigger mass air flow meter (which does not matter because i am not mass air)......oh and about 280 dollars worth of difference compared to the one I am selling.
    Nice!!! Which reminds me that I got to get a couple new bolts for the fender braces.
    Thanks!
      Upgraded Battery Cables
      Upgraded the battery cables today. The old cables werent original but they sure were skimpy so I wanted make the juice flow easier.
      Above you see the new positive cable with the old negative cable and the beginnings of a new negative cable.
      New and old negative cable
      The positive cable with the new and old negative
      And the new fat ass cables installed!
      And and old view for comparison:
        wow they were skimpy...what gauge were the old/ are the new do you know?
        -Phil
          I don't know what the before and after gauge of the wires are, but what I do know is they went from super skinny to pretty thick.
            nice little mod, right there. so vics DID come with tye downs....
            never noticed you had '79 tails-looks good! how hard were they to do? i found a set for 64 bucks, they really clean up the shape of the rear. or at least they make the blob look great
              Thanks!
              Not hard at all to install the taillights. They mount exactly the same as the originals. I believe you have to remove the entire 1/4 panel extension that houses the taillights so you can access the nuts that hold the taillights onto the 1/4 panel extension. The nuts holding the taillight to the 1/4 panel extension may be a bit rusty so before you have at it and break something you don't want to I would suggest spraying them down with some penetrating lubricant.
                Headlight Relay Upgrade
                Today I upgraded my headlights by installing a relay harness so the headlight switch does not have to handle the load of my headlights.
                This was the diagram I used to install my relays:
                And this was my little note sheet telling me what wire was which and where to land them:
                I started out by fabing up a relay box to hold the two relays required to upgrade the headlights power.
                As a box I used the fender relay cover I had left over from swapping out my inner fender to the 90/91 and up style:
                The relays I had were not large enough to fit snug in the relay box so I used some thick spongie weatherstripping I had to take up some room:
                And by adding some electrical tape around the relays they then were very snug in their box:
                Then I made up the headlight wire harness that accepts the wires from the headlight switch then spits them back out to the headlights...I used trailer wire:
                After I installed the grounds:
                Then the power:
                Now that I had the entire harness built, it was time to go and install it. Like an idiot I did not take a before pic but just run out to you car and turn on the lights and that will be your before. BTW I took the picture with the car off.
                I started by mounting my heavy duty fuse holder with a 30 amp fuse and I connected it to the starter solenoid:
                Then I mounted my relay box to my drivers side inner fender below my air box for a complete factory look:
                Then I started connecting the headlight wires to the relay harness I made.
                Here are all the headlight wires connected together with blue heat shrinked connections the red wire with black stripes is the low beam wire and the green wire with the black stripes is the high beam wire:
                Below is all the wires connected to the relays. I grounded the relay just above my washer fluid reservoir (which you can just see in the above photo):
                And power was ran through convoluted tubing through my core support, for the stealth look over to my fuse holder:
                And here are some random pictures of the complete install:
                Low beams:
                High beams:
                Took me 2 ½ hours to complete and it was totally free
                  Wow you did doing a great work!!!!!
                  1991 Mercury Grand Marquis LS - Current - June 2016 POTM Winner
                  1996 Mercury Grand Marquis LS - SOLD
                  1991 Mercury Grand Marquis LS - SOLD
                  1987 Mercury Grand Marquis LS 2dr - Long gone
                    so what is the benifit with the relays? i like how you just dident hack the whole deal, nice job
                      Thanks.
                      By utilizing the relays my headlight switch will no longer supply the power to the headlights. So my headlight switch may live long and stress free from now on. And by having the headlights directly powered by the battery/ starter solenoid they shine brighter!
                      And thank you. I do try to do everything to the best of my abilities.
                        now i reeeeeally need to do the relay, looks good!
                          Thanks
                            Daniel Stern Flasher Mod
                            Today I completed the Daniel Stern marker flash mod. Below are two threads I used to figure out how to do it and big ups for Pete on finding this cool mod out!
                            http://www.grandmarq.net/vb/showthread.php?t=5848
                            http://www.grandmarq.net/vb/showthre...ighlight=stern
                            Its really cool looking and super easy to do! AND it only took an hour to complete.
                            Here are the diagrams I made up surrounding the install:
                            It as simple as cutting two ground wires and just redirecting them to the flasher signals.
                            Here is a video of the completed install along with my headlight relay results. I even think I threw on my fog lights because a bunch of people like them in that location
                            Video
                            After watching the video I noticed my lights blink really fast....shrug....
                              hmmm neato! yeah it is flashing really fast...you look so shady with your cap on LOL
                              -Phil
                                I think my flasher is toast. It does not even make sounds inside the car. But when the hazards or on I hear the chime.
