doesn't run in very well if its already assembled tho.
I use a grease needle to apply... so it gets in pretty good.
Yeah, those engine hoists can be a real real bastard if the wheels aren't lubed. Mine was a royal pain the ass when the engine was dangling over my engine bay and I had to kick the legs to get it to move.
Scary shit.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
That's kinda how how have to force them along. Large pry bar under the legs does wonders.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Thanks for the tips!~David~
Went to the junkyards yesterday in search of some parts. I first visited Harrys in west hazelton. Boy was it dry there in the ford section they conpletely destoryed EVERYTHING.
The keen may recognize that smashed vic as the one I salvage a header panel and pedal assembly out of....
This wall of ford went two cars deep for about 700 feet. Sad sad sad.
Anyways I then went to ezpull and then found what I was looking for:
A 1999 Crown Victoria NON ABS brake booster and master cylinder. Will clean up no problem once I can separate the damn thing.
I should have harvested the brake line from the master to the drivers side brake line tee. Will do that next trip...~David~
To be honest with you. Don't even fucking waste your time with a shitty used booster. Just buy a reman one, especially when everything is new on your car already, don't cut that corner. My booster and master are fucked, since they're both JY units.__________________________________________________
I will take my chances with it as the cars entire braking system was still intact and I was able to get a firm pedal out of it. It may not look as nice as I would have wanted it to but the master was nice looking and the fluid was not horrendous either. I got the two separated earlier and will begin the clean up tomorrow. Booster will be wire wheeled and if it survives that I will put eastwoods rust convertor on it then rust encapsulator and then paint it low gloss black. The master will be engine primed, engine aluminum and clear. Its gonna be pretty!~David~
I got a nice clean booster and MC from the parts store
You will want the plug that goes into the reservoir. Its for the brake idiot light to tell you if the juice is low. I've been forgetting to pick one up for years now.86 Lincoln Town Car (Galactica).
I got it! Though I believe that with my gauges in the speedometer that the brake idiot light is no longer around.... I will connect it anyways for the hell of it.
Believe me I normally purchase everything new. I looked at the prices and said NO. I will purchase a new non abs drivers side brake hose though~David~
My car has a good pedal when the car is off, but when it's running. The pedal is mooshy.
I get a discount through my work, so a booster and master was something like 100$ for me.__________________________________________________
With regards to a booster/ MC...
Shortly after I bought my truck the reservoir cap seal started leaking. Couldn't find a replacement, so I bought a new Raybestos MC, thinking I'd just rob the gasket. When the MC arrived, it was externally larger than my original one. All the dimensions that matter checked out though. So... I decided to just use the whole new unit. Cleared it, bench bled it, etc. I pulled the booster at the same time and cleaned it up and painted it. Reinstalled everything, bled the doo doo out of the system, and the pedal was still soft, and would not return. Pissed. After much messing around, I bought a new booster. $175 for a drum brake 4WD booster (absurd). Installed, and voila! Better braking then ever. Removed and painted and all is well.
Moral of the story. Old booster was fine until I removed it and painted it. Perhaps negligence in my masking was to blame. Maybe it was just a coincidence. However, I will be very careful when masking a booster in the future. I think maybe I got cleaning solvent somewhere that I shouldn't have, and it affected the diaphragm. I was much more careful when I painted the new one. #lessonslearned.
As always, Dave, your attention to the details is on point. Keep up the great work.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
