Plastic protection???
    Does anyone know if there is a kind of plastic cling film, (or any other flexible plastic) like the stuff that protects I-pads, tablets, etc, that would be impervious to DOT 3 brake fluid?...........until I can get the proper master cyl gasket and bail, I need to stop fluid from running down the outside of the master cylinder and killing my inner fender paint!
    Thanks in advance for the suggestions.
    tape down aluminum foil and roll the back edge to make a channel to keep the fluid going where you want it. I don't know of any paint/plastic that won't eventually be pissed off by brake fluid.
      EPDM rubber is about it, though I don't know where you might find a hunk of that unless you know a guy in the roofing business. Reasonably sure rubber roof material is EPDM.
