Love the navy blue '89. Car looks sweet with those wheels!
Restored turbines.
they'll corrode if there is no clearcoat or something to seal them. Honestly, if you can swing it I'd consider clear powdercoat rather than just rattle can. It should hold up better.86 Lincoln Town Car (Galactica).
Originally posted by MrMarquis View PostHere are my restored turbines. SVT98t powder coated these for me. They are a wine/silver tutone and I have a matching set of five.
Come spring, the white walls will be cleaned up and the turbines will go on.
Damn, they came out nice.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
Mine have been holding strong for almost ten years now. I sanded mine with 320 grit wet. It was a pain! I put plain old black spray paint on from Duplicolor. I then used thinner on the edges then followed with 600 then 1000 grit. I just polish every six months or so.
I originally wanted to polish the whole wheel but the factory charcoal proved too tough. I was going to polish the ends of the fins but I decided I liked the blackout look. No regrets here.1990 Country Squire - under restoration
I just finished mine up last Friday. What a job. Most of the charcoal color in the spokes was good, but a few spots needed some touch up. Mixed some graphite wheel paint, along with some semi-gloss engine enamel. Matches almost prefectly.
The bare aluminum is sanded with 150 grit, then clearcoated with some spray can clear.
Still a bit of pitting from an old wheel weight, visible at the top of the wheel. Would have had to remove a bit of material to get rid of it completely. They look pretty good from just a few feet away.
Those look great hi-fi, I have a lead on a guy who does powder coating cheap way out in the sticks.
I have to wait a month or so to contact him as my daughter is getting married in three weeks.
Put a real strain on the fun money!
That's real nice for DIY1989 crown Vic daily driver 165k and counting!
1987 MGM 49xxx mi awaiting light resto
