Tripminder Harness vs Clock Harness
    I have been looking for a tripminder to install into my 85 vic and I finally found one but the guy does not have the wiring.
    I currently have a digital clock in my car that I want to swap out for the tripminder, so I was wondering if I could use my current harness for the clock, but add the extra tripminder wire(s)
    I'm fine with adding pins to the current clock harness, but will it connect to the tripminder at all?
    Also he says this tripminder is from an 85 Thunderbird, it should be the same as a vics right?
    your are going to need the harness the clock plug fits in to the trip minder harness i have a 82-87 harness if you want it just pm me
      Pm sent
