no-start question: most likely culprit?
    Hi folks;
    This is only the 2nd time this has happened to me, but I want to maybe get a handle on it before I get stuck somewhere.
    A few months ago, I got in the car, turned the key to turn the car on, and... nothing.
    Lights DID come on. Everything was normal, only, the starter never even tried to turn over. Just nothing.
    I tried cycling the key several times and nothing happened. I jumped the solenoid with a pair of scissors I happened to have in the car, and off I went. Next time and the next probably 200 starts, no problems whatsoever.
    Then last week, again. Had the car in neutral cause I was going to be lifting it, went to start it, same thing. No start. All the lights were on, they didn't dim as the starter drew power or anything: definitely, the starter just never got the power in the first place.
    Shifted the car to park, it started. Shut it off, shifted to neutral again, and it starts right up also.
    So I've got this happening just twice in a matter of months, it's not a big deal yet.
    I figure it can be:
    starter solenoid
    neutral safety switch
    ignition itself.
    Where would you look first?
    And what can you do about something that works basically exactly 99% of the time and has only failed twice in hundreds of successful trouble-free starts? (that is to say, how would I isolate the culprit?)
    So I'm really hoping for more of a "statistically, it's always been this for me in the past" sort of answer!
    The starter solenoid I replaced myself just for maintenance, a couple years ago.
    The neutral safety switch was replaced by someone else at some point: it's clearly aftermarket.
    Ignition switch probably virgin. Lock cylinder, I replaced, if that has anything to do with anything, about 2 years ago because it was wearing out.
    Since you say the neutral safety switch is at least newer than the car, I'd say pop the trim off the column and remove the plug on the ignition switch. I bet it has melty plastic in there.
    OTOH, my gut says it's your neutral safety switch, newer or not. Mine is flaky if the shifter isn't all the way home.
      Is there still a TSB out on these for ignition switch fires? Something to be concerned about/ upgrade?
        what year is your car ?
        does it have the starter soliniod on the fender ?
        alon
        79 Bronco XLT 129000kms
        88 LTD Crown Victoria wagon LX 223000kms
        03 Expedition XLT 256000kms
        06 Escape XLT 188000kms
        09 Focus SE 132000kms
        13Escape SEL 63000kms
          1990 and yes
          saved my ass that first time it didn't start! (since I could get right to it to start the car).
            check the plug that feeds down to the trans harness. The NSS wiring feeds through that. If that is crusty, or the connection at the NSS itself is crusty, you'll get a no-crank. Also check the small wire on the solenoid to make sure its clean and not crusty. Mine has randomly not cranked over before and wiggling that wire has gotten it to go again.
              if all that fails.....remove the steering columm cover and check the shift shaft tube.....if its starting to crack, it may not be ingauging park all the way(therefore not ingauging the NSS).....this applies to airbag steering wheel only
