CFI High idle
    CFI High idle
    My Merc is staying on high idle since the weather turned cold.
    The high idle plunger (right name?) is out keeping the idle up. Disconnecting the vacuum does not help, so I assume vacuum pulls it back.
    Temp gauge shows the motor is 185.
    I did notice the hoses weren't pressurized the other day when I changed the antifreeze, but was a very cold day.
    No fluid leaks.
    Thoughts?
    2000 Grand Marquis LS
    Mercury Owners Group member
    it stays like this for longer than 5-10 minutes? I know with mine sometimes it can take as long as 5-7 minutes at high idle before it kicks down. Had me worried at first... I did not have a temp gauge though.
    -Phil
      Yep, after my 10 minute commute it was still high. In the am start, it goes high idle then in 10-15 seconds drops down. Later on the way to work it's back up.
        it is really cold today........choke might need adjustment?.....try puttin the car in the garage overnight and see how it acts tommorow
          Does the choke have an effect on that high speed plinger?
            i think the electric plunger giggity is controlled by the ECM only, unless you've hot-wired the solenoid for manual control. There is a mechanical high idle stop that the "choke" works though. Wonder if maybe the ECT isn't going wonky and the computer thinks its never warming up.
              like gadget said check the ect first. maybe spray some carb cleaner and clean up the throttle blade maybe there is some build up there.
              1996 Mercury Grand Marquis - duals, PI cams, PI intake, J-Mod, MZT, BOC tune, 3.55s, 18in wheels
                maybe just plain old vacuum leak?
                  Sorry guys, i was away on vacation.
                  ECT?
                  The choke seems to work fine, wide open, but fast idle.
                    ect = engine coolant temperature sensor. Its the thing in the nipple where the heater hose connects. Usually it will throw a code if its faulty, but not always. Easy enough to check with a voltmeter if you have one handy. http://fordfuelinjection.com/index.php?p=28
                    Having a temperature gauge is handy, but if you don't have one, just verify it provides some sane value. If the motor is warmed up, you ought to get something in the 180-220 degrees range. If its way outside of there, the sensor is probably done.
                      I have this slimier problem, start her up, she idles high for a bit, dips back down to normal, ill drive and sometimes the idle kicks back up and I can't understand why, this only happens once in awhile so I have not hunted for a cure...
                      But when the idle does kick back up after she is warmed up I surely notice it, it will kick into gears, from drive to reverse all i will feel is a hard jerk.. It's a little scary. With or without the high idle the transmission shifts roughly out of 4th and from 1st to 2nd
                      -Matt
                      1990 Lincoln Town Car 5.0 @ 125K /// 2007 Hyundai Sonata 3.3 @ 29K
                        -Matt
                        IAC might be sticking, and how's that TV bushing for the AOD?
                          I'll give that a look.
                          It's been good lately of course.
                            Hey man thanks for the info, if it's sticking, would it need replacement or can I take it off and clean the channels and all?
                              sometimes you can get away with cleaning it up. give it a try and if it doesnt work i would suggest installing a new one.
