Tremec TKO + 351C
    Tremec TKO + 351C
    I already know what bellhousing ill need.
    But what flywheel, clutch, etc will I need?
    You'd need the flywheel diameter to match your bellhousing. The clutch diameter to match the flywheel. Find out the external balance on a 351C and you'll be good to go.
      For the clutch you'll also have to find out the size of the trany's input shaft and it's spline count and match the clutch disc to that info.
        I do know that i'll almost definately need to run a 157 tooth...
          If you are using the factory bellhousing and a factory flywheel, you are stuck with a 157 tooth flywheel and a 10" clutch.
          The flywheel is the early Mustang flywheel. The pressure plate is the '79-81 small 5.0 Mustang pressure plate. The SROD 10" clutch should work.
          The better ticket would be to either go with an aftermarket 164 tooth bell and the associated flywheel and clutch kit for a 11" clutch, or an aftermarket 157 tooth flywheel with 28oz imbalance that will take a 10 1/2" clutch/pressure plate.
            Good point. got a link to this bellhousing? Probably one of those sweet lakewood ones, isnt it?
              McCleod 8660 or Lakewood 15202
                Nice bell
                Now, how about a flywheel for a cleveland?
                I forgot the external balanece...
                  34.2 lb or 34.7 lb?
