exaust manifold bolts
    im scared to take the exaust manifolds off my 351 from the mark VI to put on headers but i dont wanna break any, is there anymore sugestions to as what to do to take em out or what to do prior taking them out?
    I'd warm up the engine, turn it off, and spray the bolts with liquid wrench..
    Wait a while, give them another good shot of liquid wrench, and maybe let it set for a few hours.
    Usually after a couple of applications the bolts will 'break free' without twisting off....
    We've broken off a few exhaust manifold bolts, and it's a PITA drilling them out, especially if you are running aluminum heads. :nonono:
    "Ad eundum quo nemo ante iit"
      Damn you guys must have bad luck, On both my cars the manifolds come out real easy. I just need to get my cheater bar out to make it easier.
        I usually only start to cringe when working with aluminum heads.
          never had a problem getting small block ford manifold bolts out........use heat if needed
            PB Blaster is your friend...
              Yeah I've not really had issues getting SBF manifold/header bolts out even after being really old. None of them needed a big cheaer bar or really a whole lot of effort to break loose. They're an exception though.
                I spreyed it with pb blaster the night before I did the exahust. Spreyed it a few times. Drove around. Next morning went to do the exahust, spreyed some more on it. They came off like butter.
                1989 LTD Crown Victoria LX.
                -3.73s' w/ Track Loc - KYB GR-2 Shocks All Around - TRW HD Cargo Coils Rear - Moog Front Coils - 1 Inch Rear Sway Bar - 4.6 Lower Air Box- Stock Headers - Off Road H Pipe - Turbo Mufflers.
                4 Door Muscle
                Supermotors
