well today I re-checked the timing and it is correct, then I swapped out the plugs (which were BLACK with carbon deposits after like 2 days of driving) I am running rich!!
the rough idle saga continues
Last edited by 89LincolnTWNcar; 01-31-2006, 09:07 PM.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.Tags: None
How are your oxygen sensors connected? Your air filter isn't clogged and the vacuum line to the MAP is in good shape, correct? If the MAP line is leaky or pinched, it could make it read low vacuum, causing extra fuel to be fed to the engine. If the oxygen sensors aren't hooked up or they aren't close to the ends of the headers, it might also give an erronous lean code.86 Lincoln Town Car (Galactica).
