Mystery oil loss
    Mystery oil loss
    My brothers 90s crown vic uses alot of oil. Not leaking and not really burning it. Tried PVC and hoses. About a quart in two weeks. Any ideas?
    2000 Grand Marquis LS
    Mercury Owners Group member
    No leaks???? Pop the breather cap off the valve cover and see if a lot of smoky oil comes out from blowby like a mofo.
      Nothing that could account for the volume lost.
      What does it mean if this is the case? Bad rings?
        Yup, you can drive it like that but it fouls the plugs easy and will plug the cats after a while.
          He hasn't said anything about the plugs fouling, will have to ask him
            rear seal? running onto torque converter, but somewhat held up by the converter hole plug, so it just slowly drips out? BTW a 90-91 CV is for the 5.0/5.8 boys. This thread may be better served there depending what year he has.
              if it'snot leaking out onto the ground,replace the pcv screen.........might be clogged.........or the engine was overheated at one time and the oil control rings on the pistons are toast.........my towncar burned a qt every 400 miles like clockwork
              scott
                Did that
                scott
                exactly, that could be it.
