Will These Fit??? update! tire question! again!
    i have a 1986 grand marquis, will these fit as direct replacements? or do i need spacers?
    KEYSTONE - ARE CHROME STEEL 16" x 8" RIMS
    5 BOLT PATTERN: 5 X 4.5
    CENTER HOLE: 3 & 1/4"
    BACK SPACE: 5"
    what size tires should i run on these rims? i havent the slightest clue!
    new question! see my last post on here
    Nick
    Should work, although that backspacing is a little much...
      will they stick out too far? or not far enough with the 5" backspacing?
      all my previous vehicles were fwd so i'm just getting used to sizes and spacing for rwd!
      nick
        Have you seen how far in the wheel wells the tires sit?
          lol got ya! i never said i was a genius, haha :slug: so they'll work?
          what about the fronts they won't rub at all?
          Nick
            They shouldn't...
            People run Mustang wheels with 1" spacers, giving a final BS of 4.72", so I think yours would clear.
              sweet cuz i just got a hell of a deal 4 of these shipped to my door for 202.00
              nick
                tailgunners are good. i use a 1" spacer with my 99 cobra wheels, final backspacing is 4.72. You p.ssibly migt need a 1/4" or so.
                '80 Town Coupé
                  nick
                    awsome deal on those
                    1999 CVPI
                    Old Rides
                    1988 Ford Mustang GT (trickflow stage 1)
                    1989 Mercury Grand Marquis LS (5.SLO)
                    1989 Ford Thunderbird SC (3.8 Supacharged)
                      what size tire should i run on these, i kinda wanted tires a little bigger in the back, the rims are 16X8 what should i get?
                      Nick
                        255/60-16 will be just an inch taller than stock 215/70-15s, if you want to go wider there is 275/50-16 for you but it's as tall as the stock tires. Play with that here: http://www.eunos.com/tirecalc/
                          will 265/60/16's work on the rims and the car on the rear end? i'm gonna have to go wider on the front but i'm keeping the same height on the front, i don't think 215's will fit on an 8" rim.
                          i'm going for raised white lettering, it'll look badass!
                            Yeah, 215s will be too narrow for the front, go for 235/60-15. The 265s will do just fine in the rear, I run 255s on my stock turbines (6.5" wide), and you have 8"-ers - just put like a 1" spacer there to center the rim over the bolting plane and you'll be good.
                              I have run 275/60R15s on stock steelies...
                              They looked fat. But they fit.
