$50 1985 grand marquis questions
    you know what FORD stands for right? Fix It Again Tony..........
      It isnt that easy, heres an abbreviated summary, you need to drop your tank and remove your old fuel pump and put in a hose for a pickup, you need a low pressure pump, if you run a mechanical you need to either dremel out the fuel pump mount or get another timing chain cover. Then you need to run the fuel line. Put on the 4bbl intake, mount the carb and run fuel lines to it. Then you must get a duraspark II ignition + distributor or go with an MSD ignition. You will also need a Lokar TV cable. Check out my 4bbl swap parts thread, and look at this site if you are still interested. http://www.jason.fletcher.net/tech/e...b/cfi-carb.htm
        I thought that was Fiat? I forgot what ford was.
          it was a joke, dale gribble said that on king of the hill about hanks truck, hank called him a dumbass cause its FIAT, ford is Found On Road Dead
            I remeber that episode, too...
            Wasnt it one of the first ones?
              yea it was the Pilot episode
                I knew it!
                so if ya wanna convert to carb, I know all about that
                  i need a extra set of hands is what i need, im in KC
                    Damn I've seen that episode too. I just didnt catch on!
                      Thats a shame, you all should know your king of the hill.
                        BAD NEWS!!!!
                        ok the head gasket is fried im pretty sure cause the upper rad hose is building pressure and the idle is increasing, anyone wanna come help me do head gaskets on it? Please i live in kansas city MO but i have a heated garage
                          I'm 17, never worked on a car before, and I did my head gaskets properly, if that helps. You just need some time, a haynes manual, and a bunch of craftman socket wrenches and a torque wrench. IF your head gasket is blown, the engine is probably a little cruddy inside and the heads are probably warped. Maybe you should put some rebuilt mustang E7TE heads on there, that would fix the warpage issue and give you about 30 more horsepower (flame on).
                            i dont have the money to buy new heads, im hoping i wont have to get them worked over but if i do it will only be $160 for both heads
                              yeah $160 sounds about right, mine were like $180 for a mill, valve job, seal job, and bead blasting and guide checking.
                                hey does anyone have a passanger side turn signal lense they could spare?
