how do you guys seal your lower intake?
    I tried it with the rubber FeltPro gaskets and gasket maker on both sides, but I have heard of professionals doing a single bead of thick RTV. What works best for you all?
    You are talking about the front and rear seals, correct? If so I heard a thick bead of rtv works great.
      yes yes front and rear seals, the sides are self explanitory
        Last time I put an intake on I did thick TRV on the front and back, and not a hint of a leak.
          RTV all the way. no leaks on mine or the 302 we built. Edelbrock even recommends using just the RTV
            whatabout the timing cover to block gasket, and the timing cover to water pump? Where can you get a timing cover to block gasket?
              mine came in the Fel-Pro full gasket kit. damn set even had new valve seals in it.along with a bunch of other gaskets i cant use. 351 throttle body gasket, egr gasket, upper-lower manifold gasket. (goddamn the ports on a factory 351 manifold are massive compared to a 302)
