Extra PVC connections - what to do with them
    Picked up a new PVC valve but the new one has extra connections. What do I do with them? Block them off?
    Never mind. That little tab tears off so you can block the extra connector.
      if this is not for a CFI car, pull the elbow off and you'll have a straight valve like the original is.
        Is the CFI supposed to have 2 lines to it?
        I have a similar PCV valve and the top nub is open.
        2005 Volvo V70 Bi-Fuel
          No, but they do have the angle. Plug the top nub if its open.
            +1, yank the whole plastic deal off and you then have the same thing as the original ('86-'91 302 panthers).
            Vic
